跳转到主内容
iPad 3 Wi-Fi Headphone Jack Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPad 3 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: 步骤 1 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: 步骤 1 中的图像 2,2
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  2. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 2 中的图像 1,3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 2 中的图像 2,3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 2 中的图像 3,3
    • Using the flat end of a spudger, pry the front-facing camera connector off of its socket on the headphone jack assembly.
    • Slide the spudger to the right, releasing the adhesive holding down the camera cable.
  3. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 3 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 3 中的图像 2,2
    • Using the tip of a spudger, flip up the retaining flap on the microphone cable ZIF connector.
  4. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 4 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 4 中的图像 2,2
    • Insert the tip of the spudger underneath the microphone ribbon cable, removing it from its ZIF connector.
    • Slide the spudger to the left, releasing the adhesive holding the microphone ribbon cable to the headphone jack assembly.
  5. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 5 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 5 中的图像 2,2
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
    • Remove the volume button ribbon cable from its ZIF connector.
  6. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 6 中的图像 1,3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 6 中的图像 2,3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 6 中的图像 3,3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.0 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  7. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 7 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 7 中的图像 2,2
    • Gently peel the headphone jack assembly ribbon cable up from the foam pad in the top left of the rear case.
    • If necessary, use the flat end of a spudger to loosen the adhesive securing the ribbon cable to the foam.
  8. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 8 中的图像 1,2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: 步骤 8 中的图像 2,2
    • Grasping the headphone jack assembly with both hands, pull the assembly from the iPad, minding any cables that may get caught.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 104
