跳转到主内容
iPad 3 4G Headphone Jack Cable Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPad 3 4G Headphone Jack Cable Replacement, Headphone Jack Cable: 步骤 1 中的图像 1,3 iPad 3 4G Headphone Jack Cable Replacement, Headphone Jack Cable: 步骤 1 中的图像 2,3 iPad 3 4G Headphone Jack Cable Replacement, Headphone Jack Cable: 步骤 1 中的图像 3,3
    • Peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  2. iPad 3 4G Headphone Jack Cable Replacement: 步骤 2 中的图像 1,3 iPad 3 4G Headphone Jack Cable Replacement: 步骤 2 中的图像 2,3 iPad 3 4G Headphone Jack Cable Replacement: 步骤 2 中的图像 3,3
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 106
