跳转到主内容
iPad 2 Wi-Fi EMC 2415 LCD Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPad 2 Wi-Fi EMC 2415 LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  2. iPad 2 Wi-Fi EMC 2415 LCD Replacement: 步骤 2 中的图像 1,2 iPad 2 Wi-Fi EMC 2415 LCD Replacement: 步骤 2 中的图像 2,2
    • The front panel ribbon cables are connected beneath the LCD. To access them, you'll need to temporarily flip the LCD over and out of the way.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its display data cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on the front panel.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 608
