跳转到主内容
加入维修社区 - 创建账户
iPad 2 Touch Screen Replacement Video tutorial
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
视频概述
  1. iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: 步骤 1 中的图像 1,2 iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: 步骤 1 中的图像 2,2
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
  2. iPad 2 Touch Screen Replacement Video tutorial: 步骤 2 中的图像 1,2 iPad 2 Touch Screen Replacement Video tutorial: 步骤 2 中的图像 2,2
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
  3. iPad 2 Touch Screen Replacement Video tutorial: 步骤 3 中的图像 1,1
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
  4. iPad 2 Touch Screen Replacement Video tutorial: 步骤 4 中的图像 1,2 iPad 2 Touch Screen Replacement Video tutorial: 步骤 4 中的图像 2,2
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
结论
4等其他人完成本指南。
ZFix
于12/09/13注册
196,358 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
332 名成员
创作了1,473篇指南
1指南评论
We replaced the screen successfully and it turns on all looks beautiful except the touch screen isn’t working at all—any thoughts? We are beginners
shelley fiedler - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 54
总计 4,614
