跳转到主内容
iPad 2 GSM Headphone Jack & SIM Slot Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack & SIM Slot: 步骤 1 中的图像 1,2 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack & SIM Slot: 步骤 1 中的图像 2,2
    • Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket.
    • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
    • Peel the headphone jack and front camera cable off the rear case.
  2. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 2 中的图像 1,1
    • Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
  3. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 3 中的图像 1,1
    • Remove the three 2 mm Phillips screws securing the SIM card slot to the rear panel.
  4. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 4 中的图像 1,1
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the top edge of the rear panel.
  5. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to help pull the headphone jack out of its recess in the top of the rear panel.
    • Don't try to remove the assembly just yet, the ribbon cables are still connected.
  6. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 6 中的图像 1,1
    • Peel the front camera and microphone cables off the rear panel.
  7. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 7 中的图像 1,2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use a plastic opening tool to disconnect the front camera cable from the microphone cable immediately below it.
  8. iPad 2 GSM Headphone Jack & SIM Slot Replacement: 步骤 8 中的图像 1,1
    • Peel the front camera cable off the microphone cable.
结论
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,427篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 247
