跳转到主内容
加入维修社区 - 创建账户
iPad 2 CDMA LCD Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPad 2 CDMA LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Remove the four 2.0 mm Phillips #0 screws securing the LCD to the rear case.
  2. iPad 2 CDMA LCD Replacement: 步骤 2 中的图像 1,2 iPad 2 CDMA LCD Replacement: 步骤 2 中的图像 2,2
    • The front panel ribbon cables are connected beneath the LCD. To access them, you'll need to temporarily flip the LCD over and out of the way.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its display data cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge closest to the volume buttons and gently flip it out of the rear case—like turning the page in a book.
    • Set the LCD face down on the front panel.
结论
Phillip Takahashi
于08/22/11注册
87,675 声望
创作了87篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 681
