视频概述
Just add air? That would be too easy. Apple has packaged all kinds of revised hardware into its thinnest tablet yet:
Fully laminated, 9.7" IPS Multi-Touch LCD with a 2,048 x 1,536 resolution at 264 ppi and antireflective coating
A8X 64-bit CPU (rumored to be a triple-core, 1.5 GHz SoC) paired with 2 GB RAM and M8 motion coprocessor
8-megapixel rear iSight camera capable of recording 1080p/30fps or 720p/120fps video + 1.2-megapixel 720p front-facing camera
Touch ID fingerprint sensor + barometer + dual microphones + 3-axis gyro + accelerometer + ambient light sensor
802.11ac dual-antenna MIMO Wi-Fi + Bluetooth 4.0
16, 64, or 128 GB on-board storage
The iPad Air 2 marks the beginning of a new model number pattern, A15XX. In this case, the iPad Air 2 Wi-Fi bears the model number A1566.
In addition to a new model number, the iPad Air 2 introduces Touch ID into the iPad family.
If you're new to the game, Touch ID allows you to use your fingerprint to unlock your iPad. You can also use it to authorize purchases from the iTunes Store, App Store, and iBooks Store.
Pencil-thin is so last year. This gold brick is now slightly thinner than a pencil.
In all seriousness, the 6.1 mm profile is impressive. Not only is the iPad Air 2 thinner than the original iPad Air, it's even thinner than the latest iPhones—and lacks the latter's controversial camera bump.
Not only is this iPad Air 2 thinner, but it is lighter too. How much lighter? About 12 pennies worth.
在这个步骤中使用的工具:iOpener$19.99
Hey, Goose! (Yes, Maverick?) I feel the need...the need for heat!
We had high hopes for finding some exterior screws on the Air 2—after all, the iPhone 6 Plus proved Apple can do tablet-sized gadgets, without the glue.
We are forced to pile on—iOpeners, that is.
Upon successfully opening the iPad Air 2, we immediately note that all the display cables now reside near the lower edge.
This is a welcome change from the previous iPad Air, whose digitizer and LCD cables effectively booby-trapped two edges of the display.
In case you were wondering how much room you have to wedge your opening pick in between the front panel assembly and rear case, it's not much. There's little margin for error in this Air 2's margins.
Our next step is to remove the FaceTime HD camera and microphone-encircled 8 MP iSight camera.
When compared to the larger, bump-inducing iSight camera from the iPhone 6 Plus, we can see they aren't quite the same—but it's indeed a leap in quality over the iSight camera found in the first-gen iPad Air.
Unfortunately, the logic board is still glued in—so we call our trusty iOpener out of retirement for one more gig.
After some careful and tedious prying, we have ourselves a logic board!
Upon removal, we are saddened to see that the Lightning connector cable remains soldered to the logic board.
At last, the main course. An entire plate of chips for us! Yum.
Apple APL1012 A8X 64-bit Processor
Elpida/Micron Technology F8164A3MD 8 Gb (1 GB) RAM (1 GB x 2 = 2 GB total)
SK Hynix H2JTDG8UD1BMR 128 Gb (16 GB) NAND Flash
NXP 65V10 NFC Controller (as found in the iPhone 6 and 6 Plus)
Apple (Cirrus Logic) 338S1213 Audio Codec
NXP Semiconductors LPC18B1UK ARM Cortex-M3 Microcontroller (Apple M8 Motion Coprocessor)
Murata 339S02541 Wi-Fi Module
More chips for those who want seconds:
Maxim Integrated MAX98721BEWV Boosted Class Amplifier
Broadcom BCM5976 Digitizer Controller
Texas Instruments TI48WHXDP 343S0583
Fairchild Semiconductor FDMC 6683 and FDMC 6676BZ (two ICs that date all the way back to the iPad 2)
Bosch Sensortec Barometer BMP280 Accelerometer BMA280
在这个步骤中使用的工具:Plastic Cards$2.99
The battery, now freed from the logic board's grasp, is ready for removal.
It looks like we're going to need more help to get out of this sticky situation. Cue iOpener.
It takes more heat and prying to free this dual-cell energy slab from the rear case.
The 27.62 Wh battery in the iPad Air 2 drops a bit from the previous Air's 32.9 Wh capacity.
iPad Air 2 Repairability Score: 2 out of 10 (10 is easiest to repair)
The battery is still not soldered to the logic board.
The LCD and front panel glass are now fused together. This slightly simplifies the opening procedure.
The fused front panel also increases the cost of repairing a cracked screen, and increases risk of damage to the LCD when opening.
Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
Gobs of adhesive hold everything in place making all repairs more difficult.
22条评论
Which 3-axis chip is in the iPad Air? Invensense, same as the iPhone 6 series?
