跳转到主内容
iON SnapCam 1046 Lite Camera Lens and Cover Replacement
你所需要的
  1. iON SnapCam 1046 Lite Camera Lens and Cover Replacement, Camera Lens and Cover: 步骤 1 中的图像 1,2 iON SnapCam 1046 Lite Camera Lens and Cover Replacement, Camera Lens and Cover: 步骤 1 中的图像 2,2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 步骤 2 中的图像 1,1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 步骤 4 中的图像 1,3 iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 步骤 4 中的图像 2,3 iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 步骤 4 中的图像 3,3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
结论
Once the camera lens and cover have been replaced, reassemble the iON SnapCam Lite by following these steps in reverse order.
Kyle Whittaker
于11/20/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S22-G4, Bayer Fall 2017 IUPUI, Team S22-G4, Bayer Fall 2017 的会员
IUPUI-BAYER-F17S22G4
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 108
