跳转到主内容
iNNEXT N64 Classic Controller Shoulder Buttons Replacement
  1. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: 步骤 1 中的图像 1,2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
  2. iNNEXT N64 Classic Controller Shoulder Buttons Replacement: 步骤 2 中的图像 1,1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
  3. iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: 步骤 3 中的图像 1,2 iNNEXT N64 Classic Controller Shoulder Buttons Replacement, Shoulder Buttons: 步骤 3 中的图像 2,2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
终点
Khaymare commock
于10/24/24注册
265 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-4, Santin Fall 2024 UMass Dartmouth, Team 3-4, Santin Fall 2024 的会员
UMASSD-SANTIN-F24S3G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 43
