Als Nächstes müssen die drei Kabel vorsichtig entfernt werden müssen.
(Von Links nach rechts) Das erste Kabel kann mit einem Hebelwerkzeug oder auch mit einem Fingernagel entfernt werden. Beim zweiten muss zuerst die Lasche nach oben, damit das Kabel ab kann. Beim dritten muss die Lasche Links am Anschluss nach oben getan werden, damit es entfernt werden kann.
Nun ist das Display entfernt und die Anleitung fertig! Für den wieder Einbau kannst du die Anleitung von 3-1 wieder befolgen.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
8等其他人完成本指南。
7指南评论
Will this cause an issue with true tone and the front camera similar to iPhone screen replacements?
True Tone will be removed however the camera will still work. The screen will work just fine
Stephen -
Where is a good place to buy replacement screens? I have and Apple 24" iMac with M1 Chip (Mid 2021, Silver) and afraid I’m going to buy the wrong screen or a fake one. Thanks for time
Apple has eliminated the ability for these parts to be available from anyone but Apple and they charge so much that you might as well buy a new iMac. So much for their supposed commitment to repairability. There whole repairability program is nothing but a forward facing PR campaign while their actual processes are meant to encourage their continued windfall from Applecare or the sale of new machines. They are happy to have you trade in your existing product that they then fix and resell, just not willing to do that at a reasonable cost for their actual customers.
Since you partner with Apple why no listing of availability of the actual part? And if it's not available what is the point of this being titled "Screen Replacement"?
