跳转到主内容
iMac Intel 27" EMC 2429 Access Door Replacement
你所需要的
  1. iMac Intel 27" EMC 2429 Access Door Replacement, Access Door: 步骤 1 中的图像 1,2 iMac Intel 27" EMC 2429 Access Door Replacement, Access Door: 步骤 1 中的图像 2,2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
    I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
    Wizbang FL - 回复
    I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
    gordonhamachi - 回复
结论
24等其他人完成本指南。
Phillip Takahashi
于08/22/11注册
86,704 声望
创作了87篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 54
总计 23,257
