跳转到主内容
iMac Intel 27" EMC 2390 Access Door Replacement
你所需要的
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: 步骤 1 中的图像 1,2 iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: 步骤 1 中的图像 2,2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
结论
12等其他人完成本指南。
1指南评论
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 34
总计 9,647
