跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide is an internal private guide used as a prereq.
配件
没有特定配件。
  1. Remove the four T10 Torx screws securing the optical drive to the outer case.
    • Remove the four T10 Torx screws securing the optical drive to the outer case.
  2. Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  3. Insert a spudger between the optical drive connector and the optical drive. Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
  4. Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
    • During reassembly, note that there are two holes in the optical drive face plate into which two stubby plastic posts must engage for proper positioning.
结论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 2,121
