跳转到主内容
iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector in the current orientation so the fans will not run at full speed. If you have multiple pins on your replacement hard drive, put the connector closest to the SATA connections and closest to the PCB board.
    • Disconnect the thermal sensor, SATA power, and SATA data cables by pulling their connectors away from the sockets on the hard drive.
  2. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two T10 Torx screws securing the upper hard drive bracket to the outer case.
  3. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 3 中的图像 1,2 iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Slightly rotate the hard drive away from the outer case.
    • Lift the hard drive off its two lower positioning pins and remove it from the outer case.
  4. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
    • Remove the upper bracket from the hard drive.
  5. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the two T8 Torx pins from the other side of the hard drive.
  6. iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Carefully peel off the piece of EMI foam attached to the front of the hard drive.
    • Don't forget to transfer this to your new hard drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 642
