跳转到主内容
iMac Intel 27 英寸 2012-2019 胶条替换
你所需要的
  1. iMac Intel 27 英寸 2012-2019 胶条替换, 确定所用的粘合剂: 步骤 1 中的图像 1,1
    • 开始之前,请确保您拥有正确的胶带:
    • 2012-2019 年 iMac 胶带具有麦克风切口,编号为 16、21、22、23、25 和 26。它们可用于 2012-2019 年 27 英寸 iMac。
    • 如果您的粘贴条编号为 11-16,请按照 2012-2015 iMac 粘贴指南 进行操作。
    Is there anything better than these self-adhesive strips?
    They don’t seem as thick as the original adhesive and not as strong. As the adhesive weakens when warm, I’ve had a screen come loose within a few days of use. Luckily the user was in front of it to catch it, else we could have been looking at a very expensive repair.
    Cool_Breeze - 回复
    Hello, in 99% of cases this happens because the residues of the old stripes on the display side have not been completely removed.
    McFix - 回复
    My strips are labelled 14, 15, 16, 21, 22, 23 in a kit for the late 2013 iMac. That matches neither set mentioned here. So I have 14 and 15 instead of 25 and 26. It seems a mix of the two sets described, but since either should work for the 2013 model I should be fine?
    Bernd - 回复
  2. iMac Intel 27 英寸 2012-2019 胶条替换, 稳定 iMac: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 27" Cardboard Service Wedge
    购买
    • 如果铰链可以自由移动,iMac 就会失去平衡,难以操作。如图所示,可以完成维修,但使用 iFixit 纸板维修楔可以使维修更快、更方便。
    • 按照 这些组装说明 将维修楔块组装在一起。
    • 如果不使用 iMac 维修楔,在显示屏后面安装和操作时要非常小心--如果 iMac 意外移动,屏幕很容易脱落和断裂。
  3. iMac Intel 27 英寸 2012-2019 胶条替换, 去除旧的胶条: 步骤 3 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换, 去除旧的胶条: 步骤 3 中的图像 2,2
    • 在安装新的胶带之前,请清除后外壳周边的所有旧胶条。
    • 如果您要重新使用现有的显示器,还必须去除显示器背面的旧粘胶条。
    • 用镊子或手指剥掉胶带。 从底部开始,“向上”向设备顶部剥离。
    • 清除所有旧粘合剂后,用 90%(或更高)的酒精和无绒布仔细清洁表面。 朝一个方向擦拭,不要来回擦拭。
    • 请勿跳过此步骤,否则新的胶带可能无法正确粘合,并且显示屏可能会从 iMac 上掉落。
    The black border on the back of the screen glass appears to be painted on. When removing the foam adhesive, be careful with tools as it can scratch off the paint and that will show through when all is back together. Fingernails worked best for me; peeling the tape up slowly followed by the alcohol wipe.
    Tom Pentz - 回复
    On mine the glue stuck mostly to the enclosure. It required a lot of elbow grease to get it off.
    Larry - 回复
    Used a little dab of Goo Gone with a micro fiber cloth and a lot of elbow grease on the enclosure to remove the adhesive. As far as the glass side, mine was fairly clean so I just used some 70 % alcohol and was careful. Then went back over all areas with 70 % alcohol again. Was able to clean everything thoroughly. It’s tough but worth it for good adhesion. Thanks Darren S.
    Darren Stewart - 回复
    My 27" iMac was damaged in shipping and I had to replace the display. When trying to replace the display, I found that the case was bent on the top, just barely visible. Makes sense as the top right corner of the display was totally smashed... Check your display fit and alignment BEFORE placing the adhesive strips. This way you can work on straightening the frame without worrying about damaging the adhesive strips.
    The case is actually soft, in that it is easily bent. Work only when relaxed and not stressed out! I used my body weight and a small piece of wood as a fulcrum to accomplish the (un)bends. If you place it on a totally flat surface you can see where it's touching and where it's high, so you know where to bent it. I had to use some pliers to get the last bit straight. I used multiple (4 - 6) layers of cardboard under the pliers to prevent scratching the aluminium. Go gently, slowly, checking for alignment / flatness many times, rather than doing too much and having to bent it back again.
    VikingShips - 回复
  4. iMac Intel 27 英寸 2012-2019 胶条替换, 将胶带铺好: 步骤 4 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换, 将胶带铺好: 步骤 4 中的图像 2,2
    • 预先铺好粘合带,这样您就不会意外地将粘合带安装在错误的位置:
    • 胶条22 在左上角
    • 胶条23 在右上角
    • 21位于右侧垂直
    • 25 在右下方,暗面朝上。
    • 仔细检查以确保该胶带有麦克风所需的切口。
    • 26 在左下方,暗面朝上。
    • 16 位于左侧垂直方向
  5. iMac Intel 27 英寸 2012-2019 胶条替换, 安装右侧胶条: 步骤 5 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换, 安装右侧胶条: 步骤 5 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换, 安装右侧胶条: 步骤 5 中的图像 3,3
    • 从 21 开始,该胶条位于 iMac 框架的右侧垂直边缘。
    • 在撕下任何背衬之前,将胶带沿着 iMac 的框架排列,以了解它的位置。
    • 从胶带背面剥下短的背衬。
  6. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 6 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 6 中的图像 2,2
    • 将撬棒的尖端插入刚刚移除一层背衬的胶带末端的孔中。 从仍有一层白色背衬的一侧插入撬棒。
  7. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 7 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 7 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 7 中的图像 3,3
    • 在撬棒仍然从胶带上的孔中戳出的情况下,将撬棒尖端推入 iMac 框架上相应的孔中。
    • 使用孔和撬棒固定胶带的位置,将粘合带与右边缘对齐,轻轻向下拉动撬棒以确保粘合带拉紧,然后将其粘贴到框架上。
  8. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 8 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 8 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 8 中的图像 3,3
    • 当您确认胶条的上半部分已整齐对齐后,从胶条后面剥出较长的蓝色衬垫。
    • 如果上半部分未正确对齐,您可以小心地将其剥离并重新粘贴,然后再剥离下背衬条。 请务必使用撬棒尖端固定顶部。
  9. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 9 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 9 中的图像 2,2
    • 将胶带的下部与框架的右边缘对齐,然后将其粘贴下来。
  10. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 10 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 10 中的图像 2,2
    • 用手指抚平胶带。 确保它与框架的右侧整齐对齐并且平放。
    • 先不要撕掉前面的背胶。
  11. iMac Intel 27 英寸 2012-2019 胶条替换, 安装顶部和左侧胶条: 步骤 11 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换, 安装顶部和左侧胶条: 步骤 11 中的图像 2,2
    • 沿 iMac 周边逆时针方向操作,以同样的方式再添加三个胶带:
    • 23在右上方
    • 22在左上方
    • 16 位于垂直左侧
    • 这三个胶条的两端各有一个孔--通常使用较小的孔对齐,以便更精确地放置。
    • 在 iMac Intel 27" Retina 5K 显示屏上,右上角胶带的蓝色卡舌不会像非 5K 型号那样与顶部天线对齐。这没问题,不会影响显示胶条或天线的性能。
    2017 27”, lining up the top strips with the smaller outside holes, the tape holes at the other end did not line up with the larger holes in the case, near the camera.
    ebay - 回复
    For the late 2012 27” iMac, strip 23 didn't line up correctly with the antenna. the antenna adhesive was a cm off from where it should have been. No biggie though.
    Daniel - 回复
    I can confirm above comment - EMC 2546 Late 2012 27" iMac, strip 23 antenna does not align with adhesive.
    Michael - 回复
  12. iMac Intel 27 英寸 2012-2019 胶条替换, 安装底部胶条: 步骤 12 中的图像 1,1
    • 接下来的几个步骤将向您展示如何安装右下角的胶带(胶带 25),其中包括一个必须与麦克风对齐的凹口。
    • 在尝试该过程之前,请通读此步骤和接下来的四个步骤。
    • 抓住胶带 25 上的红色拉片,拉动以将白色背衬与条带分离约 2 英寸(5 厘米)。
    These steps instruct you to install the lower strips to the iMac frame first, as that is what Apple instructs their techs to do. If you have an iMac without a microphone hole, you can choose to install the lower strips onto the display first. Peel the blue tab instead of the red to expose the adhesive. Carefully place the adhesive along the bottom edge of the display. The L-bend on the adhesive should match the display contours.
    Arthur Shi - 回复
    My EMC No. 2546 did not have a microphone hole, so I was confused at first. A different instructional video (https://vimeo.com/139364064) recommends placing the strips on the display instead. I installed the strips on the frame, but I reckon installation on the display glass might have been a better option, at least with no microphone hole to contend with.
    Lennart Saaf - 回复
    Yep, no microphone hole on the late 2012 27” iMac. I followed the video but I don’t think it made anything easier.
    Maybe my mistake was putting the screen back on when the frame was lying down. I was left with a mm gap on one side due to misalignment. Stand up the mac so the screen can sit on the lip and be aligned properly.
    Daniel -
    Je pense qu’il est possible de coller les adhésifs inférieurs légèrement plus haut que sur l’image, pour dégager 2mm afin de permettre à l’écran à l’horizontale de glisser latéralement pour faciliter l’alignement lors du remontage.
    stbrille - 回复
  13. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 13 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 13 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 13 中的图像 3,3
    • 将松散的白色背衬折叠成直角,然后用手指捏住折痕。
    • 这会暴露 2 英寸的粘合剂,同时将红色标签折叠开。
    I had difficulty here. The red tab wanted to pull off from the white backing.
    ebay - 回复
    It's not the red tab. It's the bond between the white backing and the adhesive that's causing the problem. When I tried to peel the white backing off, it takes the adhesive along with it. I had to detach it with my finger nail, already risking a weaker bond between the screen and the adhesive. I thought the problem was only around the edge of the strip (where I had to pull the red tab), but the whole strip was pulling the adhesive off the clear backing as I was aligning it with the iMac. This is the second time this has happened with these strips. And now I'm concerned, since the adhesive is now slightly compressed and there's a little air gap in the middle now...
    adrianfpommier -
  14. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 14 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 14 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 14 中的图像 3,3
    • 麦克风孔为中心孔,两侧有两个较大的孔。
    • 将麦克风槽口置于麦克风孔上方,将胶带与底部边缘对齐。
    • 如果您的 iMac 没有麦克风孔,请对齐条带的右端,使 L 形弯曲 位于右侧垂直胶条旁边 L 形弯头不应与右侧垂直粘合剂重叠。
    • 胶带很容易撕裂。 小心不要用力拉扯胶带。
    • 对齐条带后,小心地将左侧暴露的边缘放置到 iMac 上以确保对齐。
    Can anyone confirm that the mic is the middle small hole as the photo in step 14 appears to show a larger hole? I ask as I don’t have the mic kit and will have to cut the kit to suit my late 2015 iMac 27 retina. Thanks.
    Amuseme - 回复
    Good catch!! Yes, the mic hole is the small center hole. The step image is showing the wrong hole. I’ll upload the correct photo shortly.
    Arthur Shi -
    i have a late 2015 iMac 27” 5K (iMac 17,1) and I do not have a microphone along the bottom. I am confused because other people do?
    R L - 回复
    The 2017 iMacs (both 21.5 and 27" models) were the first to have the microphone at the bottom. Previous models had it at the top center with the camera.
    Mike Rosenberg -
  15. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 15 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 15 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 15 中的图像 3,3
    • 剥掉胶带后面的白色背衬,露出剩余的粘合剂。
  16. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 16 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 16 中的图像 2,2
    • 用手指沿着胶带的长边从左向右滑动,以确保其笔直且无褶皱,并在将胶带粘附到 iMac 时向下按压。
  17. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 17 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 17 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 17 中的图像 3,3
    • 对左下方的胶带(胶带 26)重复前面的步骤,将其沿着 iMac 的左下边缘对齐并放置。
    • 胶带的定位应使 L 形弯曲位于左侧垂直粘合剂旁边。 L 形弯曲不应与左侧垂直粘合剂重叠。
    • 应用完所有胶带后,iMac 的外观应如第二张照片所示。
    This strip is adjacent to the power supply of the iMac. Take care not to touch any part of the power supply module during this step.
    Zachary Hill - 回复
    At this point, before proceeding, I would make sure the the power supply is fully de energized(no power cord) by holding down the power button for 30 seconds!
    Macrepair SF - 回复
  18. iMac Intel 27 英寸 2012-2019 胶条替换, 更换显示屏: 步骤 18 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换, 更换显示屏: 步骤 18 中的图像 2,2
    • 轻轻地将显示屏放置在 iMac 上方并小心对齐。
  19. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 19 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 19 中的图像 2,2
    • 使用油漆工胶带或遮蔽胶带将显示屏的底部边缘暂时固定到 iMac 的外壳上。
    • 胶带可保持显示器的对齐,并允许您安全地打开显示器的顶部边缘以接触显示器排线。
    I used 2” painter’s tape to hold the display in place, but did it a little differently. With the wedge holding the iMac at an angle, I laid the display in place and felt on the sides to make sure it was centered. Then I put small strips (4-5” long) all along the sides and top, wrapping the tape around to the back of the display to hold it in place. Then tested my repair to make sure everything worked.
    I had seen some comments about problems with the strips holding in place over time, so I didn’t actually install them. Instead, I’ve left the painter’s tape on mine. I’m a week or more in, and so far there’s no sign of failure to hold. I’m going to leave it this way until I decide whether or not to replace the blade and hard drive with an SSD. I find I don’t even notice the painter’s tape as I’m using my iMac.
    paul - 回复
    Paul- If you haven’t made the move to SSD yet, i suggest you replace the SATA 3.5” HDD with a 2.5” SSD, and leave the blade SSD already installed in place. You can create a new Fusion Drive with the SATA SSD & stock blade SSD. This allows you to still take advantage of the blade SSD for extra RAM.
    I just did this myself on my Late 2015 iMac 5K with the 2TB Fusion Drive. I swapped the dinosaur HDD for a 4TB Samsung 870 QVO 2.5” SATA SSD and my computer feels like new! better than new!
    I don’t recommend replacing the blade SSD because it’s a lot more complicated and you run a real risk of damaging the logic board.
    R L -
    @R L I'm 99% certain that it is not possible to fuse two SSD drives (and certainly not advised). i.e. your 2.5" SATA SSD and your stock blade SSD. I'm about to replace the failing 3TB HDD in my Late-2013 iMac 27 (stock 128gb blade SSD). My plan, assuming the blade drive even mounts, is to format it and let it mount as a separate volume. It's too small to really be of any use and my understanding is the disparate speeds may actually reduce performance overall.
    Kupe - 回复
    I have fused the stock ssd drive with a samsung evo ssd drive for years with no problems in my 2012 iMac The downside is that to do so you have to boot from a recovery disk and do pretty complicated stuff with terminal to fuse both ssd drives. Once that's done you cannot touch your fusion drive with disk utility (mac will not reboot and you will have to erase both disk and start over). The easy option is just leave both drives separated, they work just like any standard ssd drive.
    David C. - 回复
    It seems to me that some emphasis could be added to this step. I had successfully upgraded my HDD to SDD, and I had confirmed the success of the upgrade by booting my iMac 5G 27 2017 to the Apple prompt. In this step 19, I did not use a sufficient, nor a strong enough masking tape to hold my monitor when I was attempting to remove the backing from the bottom adhesive strips in Step 23. When the tape let go, the monitor screen dropped, and unfortunately I still had the power and data cables connected. In the process the data cable and the power cable receptacle were damaged. I hope to recover by purchasing a new data cable. the power receptacle is still usable, perhaps with an adhesive tape piece over the connection. I found this procedure difficult.
    NTAbbott - 回复
  20. iMac Intel 27 英寸 2012-2019 胶条替换, 测试维修效果: 步骤 20 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换, 测试维修效果: 步骤 20 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换, 测试维修效果: 步骤 20 中的图像 3,3
    • 此时,最好测试一下你的修复工作,以确保你的 iMac 能正常工作,然后再将其重新封好。请按照以下三个步骤暂时重新连接显示屏电缆,并在从胶条上撕下保护膜之前启动 iMac。
    • 如果你已经确认 iMac 工作正常,并准备将其粘好,请跳至 步骤22
    • 轻轻地将显示数据接口插入主板上的插座。 确保将其直接按入插座并完全插入。
    • 将显示数据接口锁向下翻转到插座上。
    • 将显示器电源接口插入主板上的插座。
    After I completed this repair I noticed that the fan was spinning all the time. What is going on?
    Diane Radke - 回复
    If the fan is going constantly the thermal (temperature) sensor is likely not attached to the hard drive. It should be okay to run it like this - but it’s loud… Better to have the thermal sensor attached and configured. I bought my kit from iFixit and the sensor was wrapped in some of the paper packaging - took me a few minutes to find it.
    Greg Postma - 回复
    I used my foam support wedge to hold open the glass side from the enclosure side. I placed in in the center to even out the weight. I used the longer areas of the wedge so more was in contact with the two parts. This freed up my hands to plug in both power and data cables. *Just be careful
    Darren Stewart - 回复
    You can also use a sw version instead of a hw thermal sensor. I found on my 27 inch iMac 2019, that the hw sensor didn’t really work for me. In fact, some of the ssd cases used in the hard drive bay are made of plastic. I found for me using Mac Fan Control by Crystal Ideal a good alternative. You can use the free version, or pay for the pro version for about 15.00 dollars to have better control of your fan speed. Of course, your mileage may vary.
    George Martinez - 回复
  21. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 21 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 21 中的图像 2,2
    • 将显示屏放回 iMac 的后壳上。
    • 此时,请插入 iMac,打开电源,并在粘好计算机之前测试修复情况。 请务必检查您移除或断开连接的任何硬件的完整功能。
    • 完成后,请关闭 iMac 并“拔掉电源线”,然后再继续。
  22. iMac Intel 27 英寸 2012-2019 胶条替换, 粘好屏幕: 步骤 22 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换, 粘好屏幕: 步骤 22 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换, 粘好屏幕: 步骤 22 中的图像 3,3
    • 继续之前,请确认 iMac 已关闭并拔下电源插头。
    • 确认 iMac 功能正常后,断开显示屏电缆,小心地将显示屏向前倾斜。
    • 用镊子从上方伸入,从显示屏底部边缘直接向上拉蓝色标签,取下底部两个胶带上的薄膜。
    Here's a sure fire way to replace the LCD onto the frame. It involves using painters tape, a foam wedge and 12" Surgical Hemostat Forceps clamps. iMac is upright on a low table so I can look down into it, painters tape applied, Foam wedge keeps it at an upward tilting angle. Headlamp recommended. LCD and power display connectors have been re-attached. Carefully open the LCD from the frame, keep in mind that the 2 cables give you about 2" of space to "look down" and with your 12" locking forceps grab and lock onto the blue tabs, getting a good, firm bite and then pull upwards to detach from the bottom adhesive strips. There will be 2 of them. The pull tab may detach but not difficult to find the transparent thread to continue the pulling. When both sides have films removed, let the display rest back on the frame and plug it in. If boot screen you can then carefully again separate the LCD slightly to then easily pull off the rest of the strips. Reseal and I use 6 pressure clamps on all sides to cure.
    Macrepair SF - 回复
  23. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 23 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 23 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 23 中的图像 3,3
    • 最后一次重新连接显示器电源线和数据线。
    • 请记住将金属固定支架固定在显示屏数据线上。
    Darren Stewart - 回复
    The display I bought had some pink protective plastic film covering the camera portion of glass on the back of the display. Be sure to remove this before finally seating the display in place! Not doing so would result in improper focusing and a pink tinted picture all the time.
    VikingShips - 回复
    amazing now it won't turn on anymore. I see as green LED but that's it.
    Kerim Incedayi - 回复
  24. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 24 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 24 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 24 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • 检查网络摄像头正前方的玻璃是否有灰尘和其他污染物。如有必要,在密封显示屏之前用 超细纤维布 擦拭。
    • 在以下步骤中取下保护膜时,用一只手稳住显示屏,或将显示屏轻轻靠在 iMac 的外壳上。
  25. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 25 中的图像 1,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 25 中的图像 2,3 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 25 中的图像 3,3
    • 将左上方的保护膜标签向上拉,取下其中一面。
  26. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 26 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 26 中的图像 2,2
    • 撕下左上方胶条保护膜的另一面。
  27. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 27 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 27 中的图像 2,2
    • 重复前面的步骤,撕掉所有剩余胶条上的保护膜。
    When pulling the adhesive strips off I had one snap in half right (just the white part revealing the adhesive) one my top right corner. I panicked because there was not adhesive there so I pulled a quick maneuver. I slipped in one of the guitar pick type triangles near the gap quickly before the adhesive has set in and was then able to slip my bent nose tweezers in and grab the white tape and peal the remaining. Whew! It worked. *Just be careful
    Darren Stewart - 回复
  28. iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 28 中的图像 1,2 iMac Intel 27 英寸 2012-2019 胶条替换: 步骤 28 中的图像 2,2
    • 为确保牢固粘合,请小心地将 iMac 背面放平(屏幕朝上),然后小心而牢固地按压显示屏的所有四个边缘。
    • 撕下将显示屏固定到后壳的胶带。
    • 24 小时后检查显示屏,确保 iMac 上的显示屏没有松动。
    Before lowering the glass display, I would recommend removing the tape from the edges, in order to check that the glass is seated flush against the bottom shelf of the frame. In my case, the glass got slightly out of alignment with all the lifting and lowering of the display, and I ended up with one corner being about 1 mm above the frame ledge. Not a huge error, but regrettable, as once you start to lower the display with all adhesive exposed, there is no turning back!
    Lennart Saaf - 回复
    A big +1 to this. I had the same issue but was able to adjust the monitor before it was fully set. Hopefully the guide can be updated with this suggestion!
    I also did 1 more power on check after removing the screen after pulling the bottom strips covers off.
    Don Rhodes -
    Has anyone had the display fall out after a few days of use when the machine warms up and the adhesive softens?
    How do we prevent that from happening?
    Is it just my imagination or are the replacement adhesive strips thinner than the Apple originals? After cutting the original adhesive we are left with a thin layer on the frame AND a thin layer on the back of the front glass. To me it feels like the replacement tape is only as thick as one of these layers, so there’s less flex to take up any minor variations in level and ultimately a weaker join.
    I also have no idea if the replacement adhesive retains its grab strength once the machine warms up in use.
    Cool_Breeze - 回复
    I'm an (unauthorized) Apple computer tech and have replaced over 24 displays on 21.5 and 27" iMacs. The only time I had a display fall off was when I tried using GooGone to remove the adhesive residue. It leaves a greasy residue that is hard to remove and will prevent proper adhesion of the replacement strips. My customer found that her 27" display had fallen off TWICE (both times it miraculously ended up on their office chair with no damage). I now use 91% IPA and the flat edge of a new spudger tool to remove residue. Never had a problem since.
    I've used several different makes of strips purchased via amazon and they all work fine.
    Corey Matsumoto -
    I have the same problem. I followed the instructions exactly, after gluing the display I let the iMac lie on its back for 24 hours.
    Then I tilted the iMac forward and after 2 days the display started to peel off.
    What needs to be done so that the display does not come off? Ambient temperature? Or is it necessary to heat the display somehow after gluing the display?
    Ondrej -
    Corey, could I ask you a question? Have you successfully removed a display after it has been attached using the aftermarket adhesive strips? I didn't have a problem removing the original display adhesive, but when I decided to reopen my iMac to upgrade the SSD, I had a very difficult time, which ended up breaking the screen...Thanks very much
    S. Baxter - 回复
终点
90等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Arthur Shi
于01/03/18注册
252,726 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
8条评论
what if i dont put on new adhesives?
sean_gizzle - 回复
You cannot reuse the iMac’s foam-core adhesive. However, you hold the display in place with tape and the iMac will work fine.
Arthur Shi -
Bonjour,
Merci pour ce tutoriel. Les outils fournis dans le kit sont parfaits. Pour moi, le plus difficile a été de réaligner parfaitement l’écran sur le châssis aluminium. l’adhésif temporaire m’a aidé, mais je pense qu’il est possible de coller les adhésifs inférieurs légèrement plus haut, pour dégager 2mm afin de permettre à l’écran à l’horizontale de glisser latéralement pour faciliter l’alignement lors du remontage.
stbrille - 回复
Don't be a "Man", read all the instructions first or you WILL be buying another adhesive set.
danamyx - 回复
I had the screen off to check the drive and went very carefully through the reinstall screen process. Yes, I used the adhesive strip kit. Installed by the number. I thought it was secure and good for the duration. I was out of the office when the screen fell off and hit the floor. This is a late 2015 Imac Retina 27". I still have extended warranty coverage, but three hour round trip to take it to an Apple store. Since it appears the screen only costs $20 I'm thinking of repairing it myself. Any comments? I would also recommend putting the iMac flat and putting some weights on the edges of the screen for a day.
Leonard Jessup - 回复
DO NOT BUY THIS KIT. the tape is old and not sticky. My screen fell off overnight!!! and now I have to replace it! waste of time and money, they are charlatans!!
Francesco - 回复
Hi Francesco,
I'm so sorry to hear about this. I've brought this tape issue to our product development folks.
Arthur Shi -
What tape would you recommend getting instead?
Tyler Moore -
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 187
过去 30 天: 765
总计 39,653
