跳转到主内容
加入维修社区 - 创建账户
iMac Intel 24" EMC 2267 RAM Replacement
你所需要的
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 步骤 1 中的图像 1,1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 步骤 2 中的图像 1,2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 步骤 2 中的图像 2,2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: 步骤 3 中的图像 1,1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
结论
37等其他人完成本指南。
johann beda
于09/13/10注册
3,426 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 89
总计 27,035
