跳转到主内容
简介
Remove the glass panel to gain access to your iMac's internals.
配件
没有特定配件。
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
  1. Gently pull the glass panel straight up off the iMac.
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
结论
28等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
86,418 信誉积分
创作了132篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 9
过去的30天: 43
总计 17,331
