本指南有最近更改,您可查看未经巡查的最新版本。
简介
Remove your front bezel to gain access to your iMac's internals.
你所需要的
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
在这个步骤中使用的工具:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx screws
Four 25 mm T8 Torx screws
37等其他人完成本指南。
一条评论
Te damos las gracias por tomarte el tiempo de mostrarnos tan útiles consejos, saludos!
