当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
If necessary, de-route the LCD temperature sensor cable from behind the logic board.
Lay the iMac down on a table before you remove the LCD so that it doesn't fall.
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
Lift the right side of the display panel a few inches up from the iMac.
Do not lift the LCD all the way up; there are still connectors attaching the LCD to the internals.
With the LCD lifted, disconnect the LCD cable by pulling down.
The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
On reassembly, you may find it helpful to remove the power supply, reconnect the LCD power cable, and then reinstall the power supply.
Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
