跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to upgrade the two RAM sticks in your iMac for an instant increase in speed.
  1. Loosen the two Phillips screws securing the access door to your iMac. Both screws remain captive within the access door.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  4. Pull both RAM chips out of their slots.
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
结论
19等其他人完成本指南。
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
Fabrizio Lazzeretti - 回复
hello, i already have 2GB, is it possible to add more? thank you!
connie dekker - 回复
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
emaginechild -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 22
总计 14,975
