跳转到主内容
iMac Intel 24" EMC 2111 Bluetooth Board Replacement
你所需要的
  1. iMac Intel 24" EMC 2111 Bluetooth Board Replacement, Access Door: 步骤 1 中的图像 1,2 iMac Intel 24" EMC 2111 Bluetooth Board Replacement, Access Door: 步骤 1 中的图像 2,2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 Bluetooth Board Replacement, Front Bezel: 步骤 2 中的图像 1,1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 3 中的图像 1,2 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 3 中的图像 2,2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 4 中的图像 1,3 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 4 中的图像 2,3 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 4 中的图像 3,3
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 5 中的图像 1,1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 6 中的图像 1,3 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 6 中的图像 2,3 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 6 中的图像 3,3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  7. iMac Intel 24" EMC 2111 Bluetooth Board Replacement, Bluetooth Board: 步骤 7 中的图像 1,1
    • The Bluetooth Board is located on the lower left corner of the iMac, to the left of the RAM modules.
    • Use the flat end of a spudger to pry the Bluetooth antenna connector off the Bluetooth board.
  8. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 8 中的图像 1,1
    • Remove the two T6 Torx screws securing the Bluetooth board to the logic board.
  9. iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 9 中的图像 1,2 iMac Intel 24" EMC 2111 Bluetooth Board Replacement: 步骤 9 中的图像 2,2
    • Use the flat end of a spudger to gently pry the right side of the Bluetooth board away from the logic board.
    • Maneuver the Bluetooth board out from under the inverter cable and remove it from the iMac.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,411
