跳转到主内容
iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement, Lower Support Bracket: 步骤 1 中的图像 1,2 iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement, Lower Support Bracket: 步骤 1 中的图像 2,2
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • On at least some EMC 2544 machines, all five screws are the same size.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  2. iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement: 步骤 2 中的图像 1,1
    • Remove the lower support bracket from the iMac enclosure.
结论
Evan Noronha
于02/05/15注册
223,406 声望
创作了168篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 140
