当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Slightly lift the AirPort/Bluetooth card and pull it straight out its socket.
Do not use excessive force to pull the end of the AirPort/Bluetooth card away from its socket on the logic board. Doing so may damage the socket.
When reinstalling the card, be sure it is properly seated before reinstalling the retaining screws.
If the AirPort/Bluetooth card is properly seated, its screw holes should align with those on the logic board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
