简介
Use this guide to replace the power supply in your 21.5" Retina 4K Display 2019 iMac.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
This guide requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the board by the edges and do not touch surface components.
你所需要的
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
Run the tool up along the left side of the display.
Hold the display with one hand while using your other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
Two 21 mm screws
One 9 mm screw
One 27 mm screw
Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
To disconnect the cable, squeeze the release clip on the back side of the connector, behind the logic board, and pull the connector straight out.
Use the flat end of a spudger to press the release clip on the side of the AC inlet cable connector inward.
While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
2等其他人完成本指南。
