简介
Use this guide to replace the left speaker in your 21.5" Retina 4K Display 2017 iMac.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Gently pull the left speaker cable straight out of its socket on the logic board.
To reassemble your device, follow these instructions in reverse.
2等其他人完成本指南。
