当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
请按照本指南中的步骤升级或更换 21.5 英寸 Retina 4K 2017 iMac 中的 SATA 硬盘。请注意,如果您要升级硬盘,则需要在执行此升级之前将 clone your existing hard drive 旧硬盘内容到替换的硬盘上,以保留您的文件和操作系统。
本指南中的某些图片使用的是 2015 iMac,其视觉效果略有不同。这些差异不会影响维修程序。
你所需要的
在这个步骤中使用的工具:iMac Intel 21.5" Cardboard Service Wedge$4.99
在开始你的iMac的任何维修操作之前:拔掉电源线,按住电源按钮至少十秒钟,以释放电源的电容器。
要重新组装设备,请按照相反的说明进行操作。
82等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
35条评论
What type of SATA SSDs are compatible with iMac? I don't want to buy the kit because I have the necessary tools, but I'd like to know which brand of SSDs work the best.
>Will take any SATA SSD.
>On a mac with a fusion drive, it just removes the spinning drive from the mix, leaving you with a separate 28gig or 128 gig SSD drive that will appear on your desktop along with the newly installed SATA SSD.
>NO TEMPERATURE monitor is needed. This generation of iMacs has done away with the propietary temp sensor. It just relies on S.M.A.R.T. tech now.
Does the screen stick back on with the same adhesive or do you have to reapply new adhesive? If yes, does it come in the kit?
You have to apply new adhesive. Go slow and careful, it’s really not hard at all.
