危险
有潜在危险
如果不正确地执行这个步骤,就可能导致受伤。请保持谨慎并注意所有警告。
危险
简介
Use this guide to replace or upgrade the CPU in your 21.5" Retina 4K 2017 iMac.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
This guide is marked "potentially dangerous" because it requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the board by the edges and do not touch surface components.
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
  • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
roberttrevellyan - 回复
Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
Dan - 回复
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
  • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
添加评论
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
Moreau - 回复
Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
  • Continue running the tool up around the top left corner.
添加评论
Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
  • Cut the adhesive along the top left of the display.
添加评论
Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  • Continue along the top of the display.
  • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
In this step can I cut along the display without make any damage to the front camera?
arisnordico - 回复
Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
dv1977 - 回复
After doing the replacement the adhesive still sticks quite good enough to hold the screen in place. Maybe this isn't rock-solid, but enough for me.
Mirko - 回复
I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
Can anybody help me ? Maybe the connector cable is broken?
djfanta - 回复
Check both connectors, probably one of them not seated well
pzhivulin -
You can add a SATA SSD if you already have a PCIe SSD Factory?
kaserlik - 回复
If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the display assembly.
Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
pzhivulin - 回复
omg - forgot to switch the termal sensor from the old display...
now fan runs like crazy...
Andrei Balotescu -
Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
  • Push the tool around the top right corner of the display.
添加评论
Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
  • Wheel the tool down along the right side of the display.
添加评论
Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  • Finish pushing the opening tool to the bottom of the right side of the display.
  • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
添加评论
While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
Edgar Broekema - 回复
Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  • Gently twist the plastic card sideways to create a gap between the display and frame.
  • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
Cassio Machado - 回复
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
  • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
  • Be sure to stop before the iSight camera, or you may damage it.
添加评论
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
添加评论
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
添加评论
Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  • Gently twist the card upward, slightly increasing the space between the display and frame.
  • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
添加评论
Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
  • Slide the plastic card toward the center, again stopping just before the iSight camera.
添加评论
Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
  • Wedge the plastic card back into the top left corner.
添加评论
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
  • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
  • Begin to lift the top of the display up from the frame.
  • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
添加评论
Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8"). Hold the display with one hand while using your other hand to unplug the display power cable.
  • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  • Hold the display with one hand while using your other hand to unplug the display power cable.
It was difficult to remove this connection. I ended up having to gently pull-up vertically a little on the wire side to unsnap it about 1mm and then horizontally wiggle it out.
delacrj2 - 回复
I had a difficult time removing this connection. I had to lift the wire-side about 1mm before it unsnapped and then carefully wiggle it out horizontally.
delacrj2 - 回复
Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
  • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
  • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
添加评论
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
添加评论
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
At step 21-22, releasing the adhesive strips from the bottom of the display, I noticed a tab on the outer end of each strip. Pull the tab to remove the whole strip, no need to mess around with the plastic cards!
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
添加评论
Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
  • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
  • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
添加评论
Remove the lower support bracket from the iMac enclosure.
  • Remove the lower support bracket from the iMac enclosure.
添加评论
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
  • Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
    • Two 21 mm screws
    • One 9 mm screw
    • One 27 mm screw
At step 26, when reassembling, it's super easy to over-tighten the 9mm screw and strip the brass ferrule out of its hole in the plastic bracket (%#*@).
Remove the left and right hard drive brackets from the iMac. Remove the left and right hard drive brackets from the iMac.
  • Remove the left and right hard drive brackets from the iMac.
添加评论
The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
  • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board.
  • Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
添加评论
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
添加评论
Remove the two 7.2 mm T8 Torx screws securing the power supply to the rear enclosure.
  • Remove the two 7.2 mm T8 Torx screws securing the power supply to the rear enclosure.
添加评论
When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Tilt the power supply forward.
  • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Tilt the power supply forward.
添加评论
Pull the power supply slightly up and out from the rear enclosure. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  • Pull the power supply slightly up and out from the rear enclosure.
  • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
添加评论
Slide the power supply to the right to clear the screw posts on the rear enclosure. Slide the power supply to the right to clear the screw posts on the rear enclosure.
  • Slide the power supply to the right to clear the screw posts on the rear enclosure.
添加评论
Rock the power supply forward and remove it from its recess in the rear enclosure. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  • Rock the power supply forward and remove it from its recess in the rear enclosure.
  • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
添加评论
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Do not let any of the exposed solder joints come in contact with a metal surface, as that can cause a short.
  • Do not let any of the exposed solder joints come in contact with a metal surface, as that can cause a short.
  • Flip the power supply over to access the DC power cable connection behind the logic board.
  • Squeeze the tab on the far side of the DC power cable connector and pull the connector straight out of its socket on the back of the logic board.
添加评论
You may find it helpful to set the iMac down on its back for the next couple of steps. Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward. While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  • You may find it helpful to set the iMac down on its back for the next couple of steps.
  • Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward.
  • While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
添加评论
Remove the power supply from the iMac.
  • Remove the power supply from the iMac.
添加评论
Gently pull the fan cable connector straight out of its socket on the logic board. Gently pull the fan cable connector straight out of its socket on the logic board.
  • Gently pull the fan cable connector straight out of its socket on the logic board.
添加评论
Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
  • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
添加评论
Remove the fan from the iMac. Remove the fan from the iMac.
  • Remove the fan from the iMac.
添加评论
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
添加评论
Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive. Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
  • Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
When reconnecting the SATA cable, there is nothing to make the connector hold still, and it is hard to reach, so it took several tries. I ended up taking off the rubber baby buggy bumpers to get more room, and then jamming them back on after getting the SATA connector snugged up.
bstaud - 回复
Remove the hard drive assembly from the iMac.
  • Remove the hard drive assembly from the iMac.
When reassembling, I found it easier to loosen the HD tray screw from Step 48 and pull the tray outwards from the left side in order to plug the SATA cable in more easily.
Cool_Breeze - 回复
Thanks! I, too, had a hard time reconnecting the SATA cable.
boboswell -
And DON’T do what I did, which is to remove the left speaker - which can easily lead to breaking the cable between the power on button and the power supply. The cable is routed through a hidden slot at the very bottom of the left speaker
bsmith1 - 回复
Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
  • Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
添加评论
Remove the hard drive tray.
  • Remove the hard drive tray.
添加评论
Gently pull the left speaker cable straight out of its socket on the logic board. Gently pull the left speaker cable straight out of its socket on the logic board.
  • Gently pull the left speaker cable straight out of its socket on the logic board.
添加评论
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
添加评论
Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip. Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
  • Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
添加评论
Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables. Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
  • Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
添加评论
Flip up the metal retaining bracket on the FaceTime camera cable connector. Pull the FaceTime camera cable straight out of its socket on the logic board. This is a delicate connector that can be easily damaged.
  • Flip up the metal retaining bracket on the FaceTime camera cable connector.
  • Pull the FaceTime camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
添加评论
Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
  • Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
添加评论
Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card. Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card. Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
  • Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
添加评论
Gently pull the right speaker cable connector straight down and out of its socket on the logic board. Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
  • Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
添加评论
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board. Push the cable slightly to the right. Push the cable slightly to the right.
  • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
  • Push the cable slightly to the right.
添加评论
Peel off the tape covering the exhaust duct.
  • Peel off the tape covering the exhaust duct.
添加评论
Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
  • Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
    • Two 6.2 mm screws
    • Two 4.7 mm screws
添加评论
Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Gently pull the microphone ribbon cable straight out of its socket.
  • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Gently pull the microphone ribbon cable straight out of its socket.
添加评论
Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
  • Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
添加评论
Tilt the top of the logic board away from the rear enclosure. As you tilt the logic board, pull the right speaker connector to the right and out of the way of the board. Lift the logic board straight up and out of the iMac.
  • Tilt the top of the logic board away from the rear enclosure.
    • As you tilt the logic board, pull the right speaker connector to the right and out of the way of the board.
  • Lift the logic board straight up and out of the iMac.
  • Be careful not to snag the board on any of the rear enclosure's screw posts.
添加评论
The SATA data connector has a clip that must be pressed to allow removal. While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board. While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
  • The SATA data connector has a clip that must be pressed to allow removal.
  • While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
添加评论
Grasp the hard drive power connector and gently pull it out of its socket on the logic board. Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
  • Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
添加评论
Peel off the four black tamper-evident stickers covering the heat sink mounting screws. Remove the four T10 screws that secure the heat sink from the backside of the logic board.
  • Peel off the four black tamper-evident stickers covering the heat sink mounting screws.
  • Remove the four T10 screws that secure the heat sink from the backside of the logic board.
    • During reassembly, tighten these screws one full turn at a time, alternating in a cross pattern. This will gradually increase the clamping pressure evenly across the surface of the CPU. Continue gradually tightening the screws until they're snug and the entire spring plate lays flat against the logic board.
添加评论
Lift the heat sink retaining spring and its bracket off the logic board. Lift the heat sink retaining spring and its bracket off the logic board.
  • Lift the heat sink retaining spring and its bracket off the logic board.
添加评论
Fully loosen the three captive T8 screws securing the heat sink over the GPU.
  • Fully loosen the three captive T8 screws securing the heat sink over the GPU.
  • Remove the two 5.4 mm T8 screws securing the heat pipe to the logic board.
添加评论
Note that the CPU will most likely remain stuck to the underside of the heat sink as it's lifted out. Take care not to damage it. Lift and remove the heat sink assembly from the logic board.
  • Note that the CPU will most likely remain stuck to the underside of the heat sink as it's lifted out. Take care not to damage it.
  • Lift and remove the heat sink assembly from the logic board.
添加评论
Flip the heat sink over and use your spudger to pry out the CPU, being careful not to drop it.
  • Flip the heat sink over and use your spudger to pry out the CPU, being careful not to drop it.
  • A thick layer of thermal paste holds the CPU in place.
添加评论
Lift and remove the CPU from the heat sink.
  • Lift and remove the CPU from the heat sink.
添加评论
Use a lint-free cloth (or coffee filter) with either isopropyl alcohol or ArctiClean Thermal Material Remover to thoroughly clean the thermal paste residue from both the CPU and GPU arms of the heat sink. Once the heat sink surfaces are completely clean, use a fresh lint-free cloth or coffee filter to apply a drop of ArctiClean Thermal Surface Purifier to remove any oils and prepare the copper heat sink surfaces.
  • Use a lint-free cloth (or coffee filter) with either isopropyl alcohol or ArctiClean Thermal Material Remover to thoroughly clean the thermal paste residue from both the CPU and GPU arms of the heat sink.
  • Once the heat sink surfaces are completely clean, use a fresh lint-free cloth or coffee filter to apply a drop of ArctiClean Thermal Surface Purifier to remove any oils and prepare the copper heat sink surfaces.
  • Do not touch the copper surface with your bare fingers, or allow any dust or debris to get on it. Even a fingerprint can be a major obstacle to thermal transfer. If you touch it accidentally, re-clean it and re-apply the surface purifier.
  • Allow the heat sink to dry completely while you continue working.
添加评论
Use a spudger to gently lift the excess thermal paste residue off of the GPU. As before, use a lint-free cloth or coffee filter and the appropriate fluids to clean and prep the GPU surface.
  • Use a spudger to gently lift the excess thermal paste residue off of the GPU.
  • As before, use a lint-free cloth or coffee filter and the appropriate fluids to clean and prep the GPU surface.
  • Clean the thermal paste from the four VRAM chips around the GPU as well.
添加评论
Apply thermal pads to the four VRAM modules around the GPU. Alternatively, you can use a thick thermal paste such as K5-PRO.
  • Apply thermal pads to the four VRAM modules around the GPU.
  • Alternatively, you can use a thick thermal paste such as K5-PRO.
  • Use tweezers to peel the liner from the tops of the thermal pads.
添加评论
Check the orientation of your CPU before installing it. Small cutouts on the edges of the CPU align with notches on the sides of the socket.
  • Check the orientation of your CPU before installing it.
    • Small cutouts on the edges of the CPU align with notches on the sides of the socket.
  • Carefully align your new CPU into its socket on the motherboard, and lay it into position.
Is it possible for the 21.5, 4K model to support/handle the i7-7700k processor?
Danilo Jiménez - 回复
Speaking from experience: Yes. We dropped one into our machine a few months back and it’s working great. (As shown in the photo in the next step below.)
Jeff Suovanen -
Follow the instructions specific to your CPU type to apply fresh thermal paste to the surface of your CPU.
添加评论
Apply a thin bead of thermal paste to the GPU.
  • Apply a thin bead of thermal paste to the GPU.
  • You do not need to apply any thermal paste to the heat sink, although Arctic Silver does suggest "tinting" the surface of the heat sink. For more information on this and on thermal paste application in general, see Arctic Silver's instructions.
  • You can now reinstall the heat sink over the CPU and GPU.
添加评论
结论
4等其他人完成本指南。
Adam O'Camb
于2015年04月11日注册
27,059 信誉积分
创作了301篇指南
团队
iFixit iFixit 的会员
Community
113 名成员
创作了5,994篇指南
Can I upgrade to i7 7700K on iMac 2017 21.5inch ?
Imperius lu - 回复
In a word, yes.
Jeff Suovanen -
looking at the compare on intel’s website:
https://ark.intel.com/compare/97128,9712...
the 7700k being a 130w vs any Apple installed CPU being 65W, I’d think the the likelihood to overheat or draw too much power would be high but I don’t have enough experience to know for certain.
Ben Ninnemann -
Can I upgrade to Intel Core i7 8700K?? It’s LGA 1151… so? iMac 2017, 21,5inch
Mikkser - 回复
Hey Mikkser, 8-series (Coffee Lake) CPUs require the Z370 chipset, which to my knowledge isn’t on the 2017 iMac logic boards. The socket is the same as the last generation so you’d be able to plug an 8700K in, but it wouldn’t work.
Adam O'Camb -
Intel Core i7-8700K Desktop Processor 6 Cores up to 4.7GHz Turbo Unlocked LGA1151 300 Series 95W BX80684i78700K would that work with it
johnm - 回复
8th Gen isn’t compatible with chipset. see previous comments.
Ben Ninnemann -
The Intel Core i7 8700K is an eighth generation Intel CPU.  8th gen Intel CPU’s aren’t compatible with Socket LGA 1151 revision 1 which is what iMac’s use.  6th and 7th gen Intel Core i3/i5/i7 are compatible, but again not 8th gen.
robert_perdue -
What are the maximum specs for cpu, gpu and ram available for this device_ thank you
what I mean is: can install a i9? which is the most powerful gpu the computer will hold? is it possible to install ddr4 ram and still dont create a bottleneck in the motherboard? thanks
ivan diaz - 回复
There are no i9 CPUs on a FCLGA1151 Socket which this iMac model uses.
Ben Ninnemann -
The Intel Core i9 uses socket LGA2066 and not 1151 revision 1.   Also the GPU is not replaceable in the iMac as replacement GPU’s aren’t available and even if they were I don’t think you can remove the GPU anyway.
robert_perdue -
hi, can i use the Intel Core i7-7700K 4.2Ghz my iMac 21.5 4k 2017 instead of the 3.6ghz version? thanks a lot.
vicky - 回复
添加评论
浏览统计数据:
过去的24小时: 19
过去的7天: 101
过去的30天: 335
总计 3,458
