当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
It is recommended to first press on one side of the connector, then press on the other side until freed.
Use a pair of tweezers to flip up the metal retaining bracket on the iSight camera cable connector.
Pull the iSight camera cable straight out of its socket on the logic board.
This is a delicate connector that can be easily damaged.
Lift the logic board straight up and out of the iMac.
Be careful not to snag the board on any of the rear case's screw posts.
The I/O inputs at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
When reinstalling the logic board, check the alignment of the exterior I/O ports. The logic board can sit crooked even when secured with all its screws.
Use a USB flash drive and/or ethernet cable to keep the logic board aligned while you screw it in.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
