当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
在这个步骤中使用的工具:
购买
If necessary, use a pair of tweezers to gently peel the tape securing the left speaker cable to the SATA data/power cable.
This tape only needs to be removed if you are removing the left speaker.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
In a similar fashion, lift the combo SATA data/power cable up out of the retaining clip.
Use the flat edge of a spudger to flip up the metal retaining bracket on the iSight camera cable connector.
Pull the iSight camera cable straight out of its socket on the logic board.
Do not use excessive force. This is a delicate connector that can be easily damaged.
Tilt the top of the logic board away from the rear enclosure.
Lift the logic board straight up and out of the iMac.
Be careful not to snag the board on any of the rear case's screw posts.
The I/O boards at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
When installing the logic board, take care to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
Use a USB flash drive and/or ethernet cable to ensure the logic board is seated correctly while you screw it in.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
