跳转到主内容
iMac Intel 21.5" EMC 2544 显示器更换
你所需要的
  1. iMac Intel 21.5" EMC 2544 显示器更换, 显示器: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iMac Intel 21.5" Cardboard Service Wedge
    购买
    • 由于铰链可以自由移动,iMac将不平衡且难以操作。维修可以如图所示完成,但使用iMac维修楔更快更容易
    • 如果您使用的是iFixit iMac支架, 查看本指南 来学习如何将其组装起来
    • 在开始对iMac进行任何操作之前:拔下电脑插头,然后按住电源按钮10秒钟,使电源电容器放电。
    • 小心不要触摸电容器引线或电源背面的任何暴露的焊点。只能边缘处理电路板。
    I have (21.5 inch, mid 2017, 2.3 ghz) base model same as this but not 4k. How much max ram can I install in my iMac??
    Narendra Verma - 回复
    This guide contains many extra steps for what should be a straight forward, simple parts replacement without disturbing more than the display, left hand speaker and removal of 4 logic board screws for play. Nothing else except for the left hand speaker wire & iSight cable from logic board, the lower support bracket and loosening the speaker so as to move it around a bit.
    For the ram, I bent a pair of cheap tweezers long ago supplied with these replacement kits to the perfect angle for holding, locating and inserting the ram into the slots under the logic bd after moving each retainer w/spudger and popping out the old. Pay attention to the orientation of the ram when removing/inserting the ram! An automotive mirror is handy along with a small flashlight for closeups. Once the ram is aligned properly substitute your fingers for the tweezers, ease it into the slot, push up & engage! Reinstall screws and all else. I have done this job successfully this way countless times. For a tweezers pic contact me!
    Ross Elkins - 回复
    Additionally, if a blade is present, I install the OSx system on the blade and everything else, apps and home folders on the new SSD. You get the very fast boot off of the blade and the full ssd for all else!
    Ross Elkins - 回复
  2. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 2 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 2 中的图像 2,2
    • 从显示屏左侧靠近电源按钮的位置开始,将 iMac 打开工具插入玻璃面板和后壳之间的间隙。
    • iMac 打开工具上的轮毂可防止您将滚轮推得太远。 如果使用其他工具,插入显示屏的深度不得超过 3/8"。否则,可能会导致天线排线断裂并造成严重损坏。
    • 动作要轻柔!如果撬得太用力,玻璃可能会破裂。如果室温较低,可用吹风机加热边缘,松开胶带。
    Always use a hairdryer!! I cracked my glass
    8bit !!! - 回复
  3. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 3 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 3 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 3 中的图像 3,3
    • 使用该工具就像使用披萨刀一样--沿着缝隙滚动,它就会从中间切开泡沫粘合剂。
    • 确保始终用切割轮后面的手柄推动。如果用力拉,切割轮可能会被拉出手柄。
    • 将工具沿显示屏左侧向上移动。
  4. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 4 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 4 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 4 中的图像 3,3
    • 继续沿着左上角向上移动工具。
  5. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 5 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 5 中的图像 2,2
    • 沿显示屏左上方切开粘合剂。
  6. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 6 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 6 中的图像 2,2
    • 沿着显示屏顶部继续操作。
    • 您可能需要用工具来回切割几次,以确保尽可能多地分离粘合剂。
  7. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 7 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 7 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 7 中的图像 3,3
    • 将工具推到显示屏右上角周围。
  8. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 8 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 8 中的图像 2,2
    • 沿显示屏右侧向下滚动工具。
  9. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 9 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 9 中的图像 2,2
    • 将打开工具推至显示屏右侧底部。
    • 这时,你要用工具绕着整个显示屏转一圈,以确保切下尽可能多的粘合剂。
  10. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 10 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 10 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • 虽然打开工具可以切开大部分粘合剂,但显示屏仍会与外壳有轻微粘连。需要使用塑料卡来切开最后的粘合剂。
    • 将 iMac 面朝上放在桌子上。
    • 从 iMac 的右上角开始,在显示屏和边框之间楔入一张 塑料卡
    • 注意不要将塑料卡插入超过 3/8",否则可能会损坏内部组件。
    Don't forget to place the mac face up on the table. Unlike older models, there is no more flap at the bottom holding the display in place. If you do these steps with the Mac upright, the screen will pop out, hit your table, and shatter :( Don't ask me how I know.
    John M - 回复
    So sorry. Thanks for that caution.
    Ted Horodynsky - 回复
    Using suction cups (the ones that were made for removing the magnetic front glass on the 2011 and earlier iMacs) work well too. Place one in each top corner, while the Mac is lying face up on a table, and gently pull and it will separate the display from the main body. You might need to do a little more slicing around the edges if you did not get all the way through the first time with the roller. Then you can lift the display up at an angle to disconnect the cables.
    Peter Hillman - 回复
    This was a great idea, worked well for me. Thanks!
    Florin -
  11. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 11 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 11 中的图像 2,2
    • 将塑料卡轻轻向侧面扭转,在显示屏和边框之间形成间隙。
    • 慢慢移动,注意不要对显示屏玻璃造成太大压力,只需留出约 1/4 英寸的缝隙即可。
  12. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 12 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 12 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 12 中的图像 3,3
    • 将卡滑向显示屏中心,剪掉 iMac 右上角剩余的粘合剂。
    • 确保在 iSight 摄像头之前停止,否则可能会损坏摄像头。
  13. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 13 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 13 中的图像 2,2
    • 再次将塑料卡片楔入右上角,让它停留在那里,以防止粘合剂重新凝固。
  14. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 14 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 14 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 14 中的图像 3,3
    • 将第二张塑料卡插入 iMac 左上角显示屏与边框之间的缝隙。
  15. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 15 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 15 中的图像 2,2
    • 轻轻向上扭转卡片,稍微增大显示屏和边框之间的空间。
    • 与另一侧一样,慢慢扭转,让粘合剂有时间分离,注意不要过度拉伸显示屏玻璃。
  16. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 16 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 16 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 16 中的图像 3,3
    • 将塑料卡向中间滑动,同样停在 iSight 摄像头之前。
  17. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 17 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 17 中的图像 2,2
    • 将塑料卡片塞回左上角。
  18. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 18 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 18 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 18 中的图像 3,3
    • 如图所示,将两张塑料卡插入四角附近,轻轻向侧面扭转塑料卡,以增大显示屏与外壳之间的间隙。
    • 如果有粘在一起无法分开的部分,请停止扭动,用一张卡片切开剩余的粘胶。
    • 开始将显示屏顶部从框架上抬起。
    • 只需将显示屏抬起几英寸,显示屏的数据线和电源线仍连接在主板上。
    Ne forcez surtout pas et soulevez l’écran par les deux extrémités ! Il faut que tous les adhésifs soient bien découpés pour que l’écran se dégage du boitier sans effort. Toute torsion de l’écran peut entraîner une superbe fissure sur le verre :-/
    mf - 回复
  19. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 19 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 19 中的图像 2,2
    • 用一只手托住显示屏,另一只手拔下显示屏电源线。确保将电缆从塑料片上拔出,而不是拉扯彩色电线。
    • 将显示屏向上抬起,以便于接触到接口,但不要太用力,以免拉伸电缆并对其连接造成压力(约 8 英寸)。
    As seen in photo:
    bottom cable pulls up
    top cable cable pulls right, after safety clip opened
    airshack - 回复
  20. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 20 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 20 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 20 中的图像 3,3
    • 使用撬棒尖端撬起显示屏数据线上的金属固定支架。
    • 小心地将显示数据排线从主板上的插座中拔出。
    • 确保将显示屏数据线连接器从插座中直接拔出。
  21. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 21 中的图像 1,2 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 21 中的图像 2,2
    • 将显示屏抬起到接近垂直的位置。
    • 此时,沿显示屏底部仍有一条粘合剂,它会像铰链一样将显示屏固定在框架上。您可以将显示屏上下移动几次来松开粘胶。
    There are pull tabs at each side off the bottom edge to allow easy release of the tape
    DarrenG - 回复
    DarrenG’s observation about the pull tabs saved me a ton of time trying to pry the display as per the original instructions. Thanks!
    lesfam5 - 回复
  22. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 22 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 22 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 22 中的图像 3,3
    • 请小心不要触碰电容器引线或电源背面任何外露的焊点(红色方框)。
    • 抓住显示屏底部边缘粘胶条末端的小标签,将粘胶条拉向 iMac 顶部,将其取下。
    • 对另一条粘胶条重复这一步骤,然后取下。
    • 如果任一胶条在取下前断裂,可用塑料卡片划开剩余的胶条。
    The roller tool for slicing open the display works great for this step. Get in there like using the card and roll across the bottom to slice through the remaining adhesive.
    Peter Hillman - 回复
  23. iMac Intel 21.5" EMC 2544 显示器更换: 步骤 23 中的图像 1,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 23 中的图像 2,3 iMac Intel 21.5" EMC 2544 显示器更换: 步骤 23 中的图像 3,3
    • 将显示屏从框架上抬起,然后从 iMac 上取下。
    • 可能需要从一侧慢慢提起,与剩余的粘合剂剥离。
    • 处理显示屏时要非常小心——它又大又重,而且是玻璃制成的。
    • 在重新组装过程中,请查看我们的 显示屏粘合剂指南 来安装新粘合剂。
    After removing the display, I also removed the 3 screws for the processor fan, disconnected the power connector for it and set the fan shroud aside. Disconnecting the remaining cable (similar style to 1 of the cables for the display) that is in the way of the RAM chips is all that's left to do. I was then able to access and quickly remove the two Apple-provided RAM chips, and replace them with 3rd party RAM. Turning the iMac on its side, so that it's in a position where you're physically putting the RAM chips DOWNWARD into their respective slots is the best way to go about uninstalling and reinstalling the chips. Using a narrow but long'ish plastic spudger tool is the best way to defeat the spring-tabs which hold the RAM chips in place. After removing the LCD display, changing the RAM is about a 10 minute process!! And I'd SURE prefer not to remove all the parts and risk damage to the iMac via the standard procedure listed. As per usual, take your time and work gently :-)
    Mitch K - 回复
    Teardown the whole machine just to change RAM? While preparing to comment on this procedure I just noticed the comment made by Mitch K above. I ran pretty much the same procedure that he describes this afternoon (steps 1-23, 43-45, and step 55). Then I swapped out the original 2x4GB RAM chips for 2x8GB chips by reaching behind the logic board, releasing the spring retaining clips one chip at a time (starting with the chip further away from the logic board), pivoting the RAM towards the back of the machine, and then carefully sliding it out of the slot. I easily slid in the new chips and then pivoted them to lock them down. No hassle, no time lost. As Mitch K states above, not only is this “shortcut” method much quicker and easier, but it provides less risk of damaging cables, sockets and other delicate components during a total teardown. Why mess with the power supply board just to change RAM? I do not advise to follow the current iFixit.com procedure written by Sam Lionheart, regardless of user skill-level.
    nycsandor - 回复
    THAT sounds one !&&* of a lot easier than the full tear down. I wonder if there’s a video of the process described by Mitch K? Adding that to these verbal instructions would really help relieve the apprehension and anxiety around the process! I do sometimes find the additional warnings, though appreciated from a “safety first” perspective, are somewhat overstated. It’s been a very long time since I shorted out RAM, or fried a PCB, or broke a connector, regardless of how finicky, fragile or awkwardly designed and positioned. I may have WANTED to break something, and the air might be blue for a few seconds, but inevitably, things go back together, the start button gets pressed, the startup chime sounds, and we’re in business. Practice DOES make as close to perfect we are likely to get.
    bruce - 回复
    Mitch has the exact method that works a treat. You don’t need to follow steps 24-37 and also 40-63. Step 51 is the step to remove the camera cable and is needed. Steps 38 and 39 are for the Fan. That is all that is needed. Done quite a few like this.
    Be careful not to drop the RAM down the back of the logic board!
    By NOT removing all the other stuff you can avoid either damaging it or forgetting to plug in a cable.
    Charlie Nancarrow - 回复
    I just trued this shortcut and it was not successful. I was not able to seat both RAM chips with this shortcut, and managed to slightly damage one of the retainer clips. I simply could not manipulate the chips into and out of the slots effectively without taking everything apart as described in the full set of steps.. I ended up retracing my steps and following the entire procedure, carefully, and that worked without incident. So, bottomline, it is definitely more work to follow all the steps but from my experience, it is decidedly safer. Your mileage may, of course, vary. It was successful in the end, and I swapped out the hard drive with an ssd during the same procedure and my machine is very, very much faster.
    jan - 回复
    I have completed by following the Mitch K post and it is much easier than stripping down the whole thing, just be aware that to remove and replace the ram chips means working in a tight space, you need slim fingers and don’t be tempted to use force, take your time.
    Barrie Price - 回复
    Well, I have slim fingers, but they are 60 years old, and they don’t work like they used to! LOL.
    Jan Hogle -
    Agree with Mitch K’s procedure. The only added tip I would throw in is to use two 45 degree tweezers with their plastic covers still installed to easily pop loose the RAM. I couldn’t get the plastic spudger tool to work myself, but the tweezers easily reach the RAM clips. Just make sure the plastic covers are installed and you won’t be in danger of scratching or shorting anything out.
    charlesnick - 回复
    So thankful I discovered these comments. Saved me a TON of time! Thank you!!
    Adam Roberts - 回复
    These comments were very useful. Thank you. I just needed to modify a pair of tweezers to allow me to seat the new RAM more easily. The ifixit screwdriver wasn't able to turn some of the screws as they were installed too tightly, and I didn't want to wait to order and reveive a pair of right angled Torx screwdrivers that would give me more leverage to get those boards off.
    Upgrader - 回复
结论
要重新组装您的设备,请反向遵循这些说明,并使用我们的 胶条指南 重新安装显示屏玻璃。
70等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Sam Goldheart
于10/18/12注册
466,280 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
137 名成员
创作了17,457篇指南
22条评论
It was really easy but the display did not power on for me. Any suggestions?
Edward Bennett - 回复
I got to the point where I fit in the display back on before I pulled the covers off of the adhesive strips. I turned the computer on and the display worked perfectly. Everything worked! The camera was aligned and everything! It must’ve been beginners luck.
I turn the computer off, unplugged the display, pulled the covers off the adhesive strips, plugged the display back in and sealed the display down. When I turn the computer on again I had a blank screen. It wasn’t just blank, it never came back on. The iMac did, but the display didn’t. I tried the old display. Same thing. After some research I found that I had burned up a device on my logic board.
So, I am left with only my iPhone and don’t know how to upload a picture in comments or I would show you exactly which one it is.
Kirk D Esco -
Can you replace just the top glass panel.
colin - 回复
it’s all in one display, you cannot disamble onlye glas panel
Mr 0x01 -
Ajudou muito!!!!!!!
kelson - 回复
Done in 20 Min :D
John Grace - 回复
Merci pour ce tuto! Toutefois l’écran est vraiment très fragile et il vaut mieux attaquer directement avec le heat gun vendu par iFixit (ou un sèche cheveux) tout autour du cadre et passer la roulette au fur et a mesure pour éviter que ça craque lorsqu’on veut ouvrir l'iMac. Croyez moi ça craque super facilement si vous tentez d’y aller directement avec la roulette et les cartes en plastique! Je vous conseille aussi de mettre des gants. Je me suis ouvert un doigt la 1ere fois en glissant le long du cadre en aluminium qui est très fin. Comme expliqué dans la vidéo l'écran est plus lourd qu’on ne l’imagine, soyez prudent ;)
Daniel Lafargue - 回复
The key is to be patient. Let the adhesive slowly release. Worked perfectly. I find that old credit card, ID cards, etc work in place of an iFixit plastic card. I strongly recommend the iMac Opening Tool though.
Elvin Lucic - 回复
Also, before using iso-propyl alcohol to clean off the adhesive, first use you fingernail to carefully pull up the edge of a strip and pull on it to remove large sections easily. The bottom strip is fiddly to get an edge of but should peel off in a single piece if you get hold of either end. Makes final cleanup with iso quick and easy.
Elvin Lucic - 回复
What is the bezel made out of? I scratched the black behind the glass when removing the adhesive from the display…
Kalan Howse - 回复
Glass with black paint.
cpaden607 -
I followed the instruction carefully and replaced a hard drive and put display back I just get a black screen,I can heard the chimes but no video.
Help!!
Rosa Diaz - 回复
Check again the flat that connects the display on the motherboard, maybe you didn’t insert it correctly.
PetrosMac -
have you solved ? i had the same problem
cufre -
I completed this repair twice succesfully, but failed on my third iMac. Screen stayed dark after restart, then after it found a startup drive it just gave me blue lines. I reopened and reseated the two cables, but still nothing.
Is there a chance I connected the display data cable upside down? Going to reopen and check it.
sgust - 回复
No luck. The display data cable clearly plugs in with the gold side down, silver side up. I reseated the cable on both the display and the logic board, but still get no image. Time for a new screen, maybe.
sgust -
Very incomplete guidance . Please show how to transfer the temperature sensor cable
Yuan - 回复
There is no temp sensor cable in the 21.5in for 2012+. Only the 27in still have temp sensor cables. So very complete guide.
mdottwo -
Do you have the lcd for sale?
so.roger - 回复
Just tried this and around the middle section the adhesive is so much tougher. I forced it and the screen chipped leading to cracks. Gutted.So be careful at the middle section along the sides.
David Simmons - 回复
Great guide! Today I did 2 screen replacements with much success.
a good idea is to always check if the display is working before sealing, using the tape at the bottom was a marvelous idea. Thumbs up!
guZzy92fs - 回复
I liked the instruction on the ifixit video. I followed instructions. Checked I had power. I saw a green light inside the computer. Sealed it back up. power it on. Heard a Apple chimes, but just got a blank screen. Any ideas on how to restarted it?
William Bache - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 83
过去 30 天: 413
总计 101,421
