简介
Use this guide to replace your logic board's BR 2032 PRAM battery.
你所需要的
在这个步骤中使用的工具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
10等其他人完成本指南。
2条评论
Is this the same battery and procedure for the mid 2011 27”?
Maor Roffe - 回复
is this the solution of fixing the black screen after press the power bottom behind when starting or restart?
