简介
純前提條件指南
你所需要的
將光碟機的溫度感應器從主板上圖片位置的插槽上拔下,請平行於主板拔出
The thermal sensor connector shown in the red box is the one for the hard drive, not the optical drive. The optical drive sensor attaches to motherboard near bottom left of optical drive fan.
The guide was correct in my case that this is the Optical Drive sensor. The board has “ODD Temp” written on it. Original HD has it’s own built in temperature sensor without a separate cable to the Motherboard, which is why OWC sells a special “In-line Thermal Sensor” SATA cable with a Temp. sensor that attaches to any new hard drive itself.
amiller770 - 回复
When I was removing the optical drive cable sensor the connector came loose from the board. Is there any way to repair this?
將光碟機從顯卡熱管旁的縫隙抬起,並將其連著線移出
小心的將光碟機從機殼右側的固定扣抽出,以騰出空間拔除光碟機連接線
當你拔掉光碟機溫度傳感器後,你可以讓光碟機垂下來
On the reassembly, I found threading the optical drive cable back under the GPU frame trying. Here’s some advice: Take some dental floss, form a loop, and feed that loop under the GPU frame. Put the cable into the loop of floss, tighten the loop, and pull the loop back through. This is much easier, faster, and far less frustrating.
將光碟機傳輸線拔除
將光碟機從iMac上拿出
I have already installed the second SSD drive, but due to the size of the drive I need to change it with another SSHD 1 TB drive. Am I right that I have to follow the instructions up to Step 18? Because The SSD is already behind the optical drive, so what I need to do is remove it and install the new SSHD drive and put everything back again. Please confirm.
This was my only error on reassembly. The SATA cable must be under the black plastic prong. I did not want to pull to logic board again. I managed to bend the black plastic bits and get the cable in the right place.
要重新組裝你的裝置,請倒序觀看指南
要重新組裝你的裝置,請倒序觀看指南
2等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
In my case the red screw was on the lower left side near the power-data cable!
sefw4t2efwef - 回复
Same here. There are different versions delivered
Tai - 回复
Same for me.
davidevismara - 回复
