简介
Use this guide to replace a broken optical drive.
你所需要的
在这个步骤中使用的工具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
41等其他人完成本指南。
4条评论
Great tutorial. Now if I wish to replace the Superdrive by an SSD (the Superdrive is dead), since the SATA port of the Superdrive is 3Gb/s only, can I keep the Superdrive cable for the SSD but swap it plug to the free SATA III port on the motherboard? Or do I need a new cable?
Thanks
What kind of caddy do I need if I want to put an SSD in there? Is it 9.5mm or 12.7mm? Is any of it non-standard?
Hi! 12mm for imacs and 9 to macbooks... but 9 fits too cuz the place in imac is bigger (also 12 on macbooks not fit)
