简介
升级你的硬盘来扩容储存空间。
在玻璃面板顶部的两个角上放置吸盘。
如果您的吸盘无法吸住,尝试使用温和溶剂清洁玻璃面板和吸盘。
按照本指南相反步骤来重新组装设备。
按照本指南相反步骤来重新组装设备。
212等其他人完成本指南。
特别感谢这些译者︰
80%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
57条评论
Hi guys, the tools arrived today and I did already chage the default harddisk against the WD Velociraptor 500GB. For now everything is working fine. The iMac is in the middle of restoring the time maschine backup. Everything worked out as described. Excellent! I was just a little surprised by the magnetic forces which one needs to overcome gently...
Is there a temp sensor that monitors the HD? I did the upgrade but now my fan is always on. I must've done something wrong.
Did you use the same brand hard drive? Did check the instructions about cable orientation on the hard drive? Did you double check the LCD thermal sensor cable?
Take a glance at this page for full explanations:
http://www.hddfancontrol.com/imac-hard-d...
I had the same issue here (after replacing the original HDD by a 1TB WB Caviar Blue) and it has been fixed by this utility.
HTH,
In response to the software, that does work, however, it can be taken care of hardware wise if our recommendations are followed.
