跳转到主内容
iMac Intel 21.5" EMC 2428 Audio Ports Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 21.5" EMC 2428 Audio Ports Replacement, Audio Ports: 步骤 1 中的图像 1,1
    • Remove the two 5 mm T10 Torx screws securing the audio ports to the outer case.
  2. iMac Intel 21.5" EMC 2428 Audio Ports Replacement: 步骤 2 中的图像 1,2 iMac Intel 21.5" EMC 2428 Audio Ports Replacement: 步骤 2 中的图像 2,2
    • Press both audio ports down slightly, then lift the audio port assembly out of the outer case.
    • A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
    • During reinstallation, it may be helpful to plug in a pair of headphones to each jack before tightening them down completely.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 173
