当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
These screws will remain captive in the access door.
Remove the access door from your iMac.
During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
Grab the RAM chip by its edges and pull it straight out of its slot.
If two RAM chips are installed, repeat this process for the other chip.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
