跳转到主内容
iMac Intel 21.5" EMC 2308 CPU Fan Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 21.5" EMC 2308 CPU Fan Replacement, CPU Fan: 步骤 1 中的图像 1,1
    • If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
  2. iMac Intel 21.5" EMC 2308 CPU Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
  3. iMac Intel 21.5" EMC 2308 CPU Fan Replacement: 步骤 3 中的图像 1,1
    • Peel the cable retainer off the side of the CPU fan.
    • If the tape on the cable retainer loses adhesion, remove the existing foam tape and either use double-sided tape or glue to reattach it to the CPU fan.
    • Remove the CPU fan from the outer case, minding any cables that may get caught.
  4. iMac Intel 21.5" EMC 2308 CPU Fan Replacement: 步骤 4 中的图像 1,1
    • De-route the left speaker cable from the clips securing it to the outer case.
  5. iMac Intel 21.5" EMC 2308 CPU Fan Replacement: 步骤 5 中的图像 1,2 iMac Intel 21.5" EMC 2308 CPU Fan Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 10
总计 2,762
