跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
iMac Intel 21.5" EMC 2308 显示屏更换
你所需要的
  1. iMac Intel 21.5" EMC 2308 显示屏更换, 玻璃面板: 步骤 1 中的图像 1,2 iMac Intel 21.5" EMC 2308 显示屏更换, 玻璃面板: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    购买
    • 在开始之前,将您的iMac如图所示放倒在柔软的表面上。
    • 在玻璃面板顶部的两个角上放置吸盘。
    • 要使用我们的吸盘时,首先将吸盘的活动手柄扳动到与玻璃面板平行位置。 在吸盘轻轻地吸在玻璃面板上时,扳动活动手柄使其与另外一个手柄平行。
    • 如果您的吸盘无法吸住,尝试使用温和溶剂清洁玻璃面板和吸盘。
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - 回复
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - 回复
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - 回复
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - 回复
    Nails worked for me too
    Rob Dale - 回复
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - 回复
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - 回复
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - 回复
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - 回复
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - 回复
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - 回复
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - 回复
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - 回复
  2. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 2 中的图像 1,2 iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 2 中的图像 2,2
    • 轻轻地竖直提起玻璃面板到足够高的高度来接触玻璃面板顶部下的卡扣。
    • 将玻璃面板拉离iMac的下部,并将面板放在一边。
    • 在重新组装时,请确保已经清理了玻璃面板内部,和LCD表面。当打开电脑时,没人希望看到屏幕里面满是 灰尘和指纹,这样你会抓狂的。
    What's the best product to clean the face of the LCD?
    Steve Speirs - 回复
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - 回复
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - 回复
  3. iMac Intel 21.5" EMC 2308 显示屏更换, 显示屏: 步骤 3 中的图像 1,3 iMac Intel 21.5" EMC 2308 显示屏更换, 显示屏: 步骤 3 中的图像 2,3 iMac Intel 21.5" EMC 2308 显示屏更换, 显示屏: 步骤 3 中的图像 3,3
    • 移除8颗将显示屏与外壳固定的 8mm T10 Torx 螺丝。
    • 后两张图片为显示屏左右两侧的细节图。
    On reassembly, it is REALLY HARD to align those screws, because of the field of the strong magnets that hold the glass cover on. I'm sure there's a trick to it, but I'd love to know what it is for future reference.
    Peter Shenkin - 回复
    I used needlenose pliers and the T10 to align the screw into the hole. Otherwise the screw keeps jumping to the magnet. And patience with this NON-CAPTIVE screw design (c’mon Apple, even **I** came up with that, and I’m an idiot!)
    finnik2d - 回复
    A short piece of small gauge vinyl tubing that fits tightly over the head of the T-10 driver leaving an 8th of an inch or so in which to insert the screw to engage the head will hold the screw long enough to keep it away from the magnet and get it going in the hole.
    Paul Boudreau - 回复
    I use non magnetic SS curved tip tweezers together with a magnetized #10 torx bit both to remove and reinstall the screws. You can magnetize and demagnetize the bit using the strong magnets on the LCD frame. Don't worry too much during removal, you can recover the screw. But loath the moment you drop the last screw during reassembly. For that reason, reinstall the screws near the magnets and hardest to get to first.
    Michael Ben-Yehuda - 回复
  4. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 4 中的图像 1,1
    • 轻轻从显示屏顶部提起,将显示屏从外壳中移出。
    • 切勿提起过多,仍有许多线缆将逻辑板与显示屏相连。
    When putting the display back I have resistance from the foam elements (on the top end where the iSight is) and have to press down really hard. Is that okay?
    gm.konsortium - 回复
    Well, stupid me put the 3.5" to 2.5" cage the wrong side up. ;)
    gm.konsortium - 回复
    Standing the imac upright on its stand really helps this step! Laying it falt makes getting under the panel a real hassle.
    finnik2d - 回复
  5. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 5 中的图像 1,3 iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 5 中的图像 2,3 iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 5 中的图像 3,3
    • 从iMac左上角处的LED驱动板上的插座中拔出垂直同步电缆。
    • 垂直同步电缆是ZIF型端子,但插座上没有锁定或挡板。 只需将电缆从其插座向iMac的光驱侧拉出,即可将其与LED驱动板断开连接。
    The vertical sync cable was snug initially and now is loose. I checked and the cable is intact. Has anyone had experience with making it fit better?
    Rajan - 回复
    Scotch tape on the upper side and sliding this in helped to secure the cable.
    Rajan - 回复
    Reassembly of this part was the closest I came to disaster on this project. I tried inserting the connector a few times without success, and when I looked it it the leads, which are fragile, were all mangled. I smoothed them out by hand as best I could and and reinserted, very carefully this time. The trick is that the tip of the connector should be pointed somewhat upwards when reconnecting.
    I was pretty sure that when I was done, I would reboot but have no display; but fortunately, everything worked.
    Peter Shenkin - 回复
    Hi, I still have a question. What is the "Job" of the vertical sync ribbon cable. Thanks
    Lutz Blum - 回复
    So let’s say someone wanted to suck some of the dust off the back of the display before reassembly. Let’s just say that. Someone would likely suck this forsaken cable up into the vacuum tube then, wouldn’t they? They might. And if it were to oscillate in a rushing torrent of air, it might get munged? It might.
    Here’s how you overcome such a disaster:
    1) cut the end fresh, as close to the end as you can while cutting off any frayed end.
    2) abrade the end gently, repeatedly, along the connector wire axis. I used emory paper. Your goal is to expose the copper conductors in the last 1/4” of the fragile evil wire.
    3) Tape a small stiff cardstock to the back of the end of the connector. This is essential to press the connector wires into the connector.
    4) Gently insert, taking special caution to not peel the copper off of the connector.
    5) Tape that connector down deftly, without letting it move a millimeter and securing it for all time.
    sydnius - 回复
    I just leave it connected. After disconnecting the other cables, there is enough slack to lay the display on its backside if you’re working on a flat surface.
    Duane Johnson - 回复
    I have replaced the hdd in this model about 8-10 times - I have never had to disconnect any cables other than the sata and temp sensor cables on the hdd. I just prop the lcd up with an egg carton (or something about 3 inches high that is soft and light) and access the hdd that way. The only thing I ever have trouble with are is putting the LCD screws back in around the magnets - but I have pretty much perfected that with a sissor/ tweezer tool.
    Suzanne Levy - 回复
    Could you put up some photos of this procedure - egg carton etc…
    Peter Barnett -
    Any ideas where to replace this cable?
    Danny Shaw - 回复
    I followed Suzanne’s comment and also did not disconnect this cable (vertical sync ribbon cable) to avoid damage. I pivoted the screen about 110 degrees after the other cables where detached. On a flat surface, this is easily done and the cable is not tight. Image of my angle if I can drop a link. and cable in this position not in tension.
    investments kkl - 回复
    Where can I buy the replacement for this vertical sync replacement cable?
    Neil Gonsalves - 回复
  6. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 6 中的图像 1,3 iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 6 中的图像 2,3 iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 6 中的图像 3,3
    • 将显示器从外壳提起到足高度来从LED驱动板上断开LED背光线缆。
    • 通过按住锁定机构,同时将连接器从其插座(朝向iMac的底部边缘方向)拉出来,来断开LED背光电源线。
    I found it easier to very slightly lift the front edge of the black connector with a small spudger, then gently pulling away towards the bottom of the iMac. Pressing felt a little crude and didn’t work for me.
    Anthony C Carnell - 回复
  7. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 7 中的图像 1,1
    • 同时挤压两个显示排线上的连接臂来将其从逻辑板上解锁。
    • 将显示线缆从逻辑板上的插座中拔出。
    in Step 7, my connector (new 21.5 iMac - Dec 2010) was not attached that way and just came of easily.
    erin - 回复
    Aperte as duas exibição do conector do cabo de dados braços juntos para desbloqueá-lo de seu soquete na placa lógica.
    Darlan Perira da Silva - 回复
    I accidently broke the data cable socket on step 7. Any advice on what i should do?
    Sam Tang - 回复
    I feel pretty silly. I spent wayyyy too long trying to get these cables disconnected. Happy I found this guide; hopefully, I won't struggle with such simple things since you provide pretty good details! Thanks.
    J.w. - 回复
    Pas beaucoup de place pour déconnecter ce cable ! En essayant d'ouvrir trop l'écran pour passer mes "grosses mains" j'ai cossé le connecteur : je suis dans le caca :-( (et pourtant j'en fait des démontages !) Alors ATTENTION !!!
    divers - 回复
    Il vaut mieux déconnecter la partie du côté écran en premier (sous l'autocollant noir)
    divers - 回复
    Je suis d’accord. C’est plus facile. Merci mon ami
    Anthony C Carnell -
    Translation: It is better to disconnect the screen side first (under the black sticker)
    Michael Seiler -
    ALWAYS ALWAYS ALWAYS REMOVE THIS CABLE!!! Even if you are "only in there for a minute" tearing the connector off the board is EXTREMELY easy.
    DistroHopper39B - 回复
  8. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 8 中的图像 1,1
    • 在逻辑板上的插座中断开LCD热传感器线缆。
    • 如果在您重新组装电脑后风扇一直全速运行,请检查此连接线或硬盘驱动器的热敏传感器线缆。
    This is important regarding the fan running full speed
    http://blog.macsales.com/19617-diagnosin...
    tobykirkland - 回复
    Is there a way to test the power supply to see if it's dead?
    professorminh - 回复
    Achtung! Dieser Stecker kann sehr fest sitzen, hier hilft ein guter Fingernagel um den Stecker abwechselnd rechts und links zu Hebeln
    bluesoundsmusic - 回复
    English translation of bluesoundsmusic comment: “Caution! This plug can be very tight, here a good fingernail helps to lever the plug alternately right and left”
    investments kkl -
  9. iMac Intel 21.5" EMC 2308 显示屏更换: 步骤 9 中的图像 1,1
    • 小心地从您的iMac顶部提起显示屏,并将其从外壳中移出。注意线缆可能会卡在显示屏中。
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
36等其他人完成本指南。
由衷感谢以下译者:
en zh
90%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
i have a problem with my pc.
when i turn on my computer couple i had lot of times the LCD turned off.
is the time to change it? The boot and the system runs ok... what's the problem?
need help guys!
Massimiliano Sartorello - 回复
good morning everyone. I have a problem with my iMac. unfortunately the screen starts to look with horizontal stripes. after verifying that it is not by the graphics card, I bought a led a different model and some connectors are different. He led riding my iMac is lm215wf3 (sl) (a1) and I bought by mistake lm215wf3 (sd) (a1). several problems. the temperature sensor input is different, and led backlightsync also is different.
Borja - 回复
Thanks for posting this guide. I had a bad display connection that caused my Mac display to go off (black) every now and then. Remote desktop showed Mac was fully functional, though. Removed the glass, removed the LCD as per this guide, cleaned all display connectors with WD40, mounted everything back and… voilà !
Martins Jr - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 128
总计 55,820
