跳转到主内容
iMac Intel 20" EMC 2266 Optical Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,2 iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Peel the strip of EMI tape off the edge of the rear case.
  2. iMac Intel 20" EMC 2266 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two T10 Torx screws securing the optical drive to the rear case.
  3. iMac Intel 20" EMC 2266 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • If necessary, remove the piece of tape holding the thermal sensor wires to the hard drive.
  4. iMac Intel 20" EMC 2266 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  5. iMac Intel 20" EMC 2266 Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the rear case.
  6. iMac Intel 20" EMC 2266 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 752
