跳转到主内容
iMac Intel 20" EMC 2266 Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 20" EMC 2266 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 iMac Intel 20" EMC 2266 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 iMac Intel 20" EMC 2266 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • To remove the hard drive bracket, squeeze the middle against the side of the hard drive while rotating the top left edge toward yourself.
    • After the left edge has been freed, rotate the bracket toward the right edge of the hard drive.
    • Lift the hard drive bracket straight up off the chassis.
  2. iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • If present, remove the small piece of tape covering the hard drive and optical drive temperature sensor cables.
  3. iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the hard drive temperature sensor cable straight away from its socket on the logic board.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  4. iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 4 中的图像 1,2 iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Rotate the top of the drive toward yourself, then lift the hard drive straight up off its lower pins.
    • The hard drive is still connected via the SATA cables.
    • When reinstalling your hard drive, be careful not to push the rubber grommets through the openings in the chassis with the lower hard drive pins as retrieving them may require logic board removal.
  5. iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 5 中的图像 1,2 iMac Intel 20" EMC 2266 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Insert the flat end of a spudger between the SATA data cable and the edge of the hard drive.
    • Twist the spudger to separate the SATA data cable from the hard drive.
    • Disconnect the SATA data cable from the hard drive.
    • Repeat this process for the SATA power cable.
    • Lift the hard drive out of your iMac, minding the thermal sensor cable that may get caught.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,713
