简介
移除维修孔盖来更换内存条或打开您的iMac。
你所需要的
即将完成!
若想重新组装设备,请倒序按照本指南操作。
结论
10等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Kevin Fu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
The grid won't fall off by itself. You'll have to help it. Use the smallest screwdriver you have; the Torx 6 worked fine for me. It should enter in one of the many holes composing the grid. Use it as a lever to ploy the grid a little bit. You may catch it with your fingers and that's it.
Be carefull not to damage the hole by a too strong leverage.
Laurent - 回复
much more safer to use duct tape, instead of torx 6. (glue it along the length of the grid and pull). it will loose instantly and smooth;)
Hofmann78rus - 回复
Anyone know a guide to replace the plastic piece this screw connects to? I accidentally forgot this step - went to remove the front bezel and bent the plastic piece the access door connects to.
Jason Augustin - 回复
