跳转到主内容
iMac Intel 20" EMC 2133 和 2210 硬盘更换
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
  1. iMac Intel 20" EMC 2133 和 2210 硬盘更换, 硬盘: 步骤 1 中的图像 1,1
    • 如果有必要,请移除您iMac上的除硬盘/光驱温度传感器线缆的固定胶带。
    Pull the temperature sensor cable for the optical drive well out of the way so you don't trap it when inserting the new hard drive.
    kevinp - 回复
  2. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 2 中的图像 1,1
    • 径直从您的iMac上拔出硬盘温度传感器。
    • 移除此连接器时,您的大拇指指甲有助于将连接器两侧的耳朵推向您的iMac顶部来移除连接器。
    I didn't do this on my 2133; just pushed wires out of the way.
    robgendreau - 回复
    Rather than disconnect this cable, you might as well jump ahead to steps 19-21 and remove the sensor from the drive.
    kevinp - 回复
  3. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 3 中的图像 1,2 iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 3 中的图像 2,2
    • 向下按硬盘驱动器支架的顶部将其从后壳释放,需要很大的力气。 我们建议您将iMac放在桌子上,以免撞倒。
    • 将硬盘驱动器支架向下移动到iMac的底部边缘以将其从后壳中取出,然后将驱动器的顶部朝向您的方向旋转。
    At first it looked like it needed extra force, rather stand the computer in its stand press the bracket firmly it will come out.
    Great set of instructions altogether!
    Jim Laredo - 回复
    I just braced the foot/stand against my thigh and found there wasn't much force needed. Had to do it twice as I missed the foam pad on the drive I was replacing.
    The whole process was simpler than I expected.
    I seem to have missed something somewhere as I now have a lot more fan activity than before. A missed sensor connection maybe. Not looking forward to tracking it down.
    paul beard -
    I worked with the top of the screen facing me. It was very easy to brace my fingers and press with my thumbs to release the drive. I recommend doing it that way if you can.
    marcintosh - 回复
    I just used pliers….. Easy!
    Dennis Postma - 回复
  4. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 4 中的图像 1,2 iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 4 中的图像 2,2
    • 将硬盘驱动器朝向你自己转动,然后将其从其安装针上提起。
    • 硬盘驱动器仍然通过SATA电缆连接。
    • 重新安装硬盘驱动器时,请勿将橡胶密封垫通过机箱底部的下部硬盘引脚推出,否则可能需要卸下逻辑板。
    During reassembly make sure not to trap the cable for the temperature sensor on the superdrive -- it goes on top of the new hard drive.
    kevinp - 回复
  5. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 5 中的图像 1,1
    • 在SATA电源线连接器和硬盘驱动器边缘之间插入撬棒的扁平端。
    • 旋转撬棒将连接器与硬盘分开。
  6. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 6 中的图像 1,1
    • 从硬盘上拔出SATA电源接头。
  7. iMac Intel 20" EMC 2133 和 2210 硬盘更换: 步骤 7 中的图像 1,1
    • 从硬盘上拔下SATA数据线缆。
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
4等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
一条评论
Walter, I was working on a mid-2007 IMac (2133) and found your instructions helpful but not always complete or right. I have added some comments in some of the steps to clarify.
Pablo Guerrero - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 2,890
