跳转到主内容
iMac Intel 20" EMC 2133和 2210 玻璃面板更换
你所需要的
  1. iMac Intel 20" EMC 2133和 2210 玻璃面板更换, 玻璃面板: 步骤 1 中的图像 1,2 iMac Intel 20" EMC 2133和 2210 玻璃面板更换, 玻璃面板: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    购买
    • 玻璃面板固定在前外壳上,周围有十四个磁铁固定。
    • 在玻璃面板的对角线上吸上两个吸盘。
    • 要使用吸盘吸的牢固,首先将吸盘可以活动的把手移动使其与玻璃面板平行。 在轻轻地将吸盘保持在玻璃上的同时,抬起活动手柄直到与另一个手柄平行。
    • 如果您的吸盘无法吸上,尝试使用温和溶剂例如Windex来清洁玻璃面板和吸盘。
    At this stage and later handling the LCD I found thin cotton gloves helped to reduce smudges
    john31 - 回复
    My GPS unit's car mount suction cup worked nicely here - couldn't find any at the store and didn't want to wait for mail order!
    Two cups would make it easier but one is fine if you place it in the center and are careful to pull the panel straight out.
    Mathew Hendry - 回复
    Why use suction cups when some finger nails will do the job nicely, though a plastic spudger might work too. Start at a top corner. Prize the glass away from the case and leave finger nails in. Move the other hand along the top edge and then with finger spread peel the screen cover away. Be careful not to twist plastic I suppose, but I've had no difficulties.
    damianwise - 回复
    3M Command Strip hooks in opposite corners is another fabulous option when suction cups are not available!
    Adam McCombs - 回复
    Tape works fine, here. Search for a YouTube video for a simple look-see.
    Richard - 回复
    I didn't have any suction cups, but my pencil sharpener (the kind that suctions to the table) worked great. I put it on the middle and lifted straight up.
    Lisa Mac - 回复
    For a quick 'n' dirty alternative "tool" for this step, take a look at IKEA's Stugvik suction hooks: they provide an excellent adjustable grip. Just used it to take apart an EMC2133. Cheers!
    hadderakk - 回复
    Suction cups usually available at Home Depot or Lowes, in the flooring section. (They're used to handle large ceramic & stone floor tiles.)
    Griff in Fairbanks - 回复
    I can confirm it is fairly easy to pull it up, the heavy duty suction cups were adequate of course, but pretty sure you can do it without heavy duty stuff? Panel is rather light too.
    Julien - 回复
  2. iMac Intel 20" EMC 2133和 2210 玻璃面板更换: 步骤 2 中的图像 1,1
    • 小心,竖直的从iMac上提起玻璃面板。
    • 玻璃面板周围有几个定位销。 为了避免将玻璃面板上的这些针脚弄坏,请务必在拆卸过程中竖直向上拉动。
    • 在重新安装之前,请务必仔细清洁LCD和玻璃面板的内部面板,因为当显示屏打开时,你不想被任何指纹或灰尘所困扰。 将玻璃平面放置在干净的铝箔表面上是保持清洁的最好方法。
    In order to avoid unnecessary smudges and what not I covered the LCD itself with some plastic wrap while doing the hard drive upgrade. When I reinstalled it all I needed to do was blow off a few dust particles.
    robgendreau - 回复
    While you are at it, it is worth cleaning out dust within the case to help with cooling - particularly around the fans and vents.
    For the screen I used a lens cleaner from my camera bag. These have very fine fibers and won't leave detritus.
    Mathew Hendry - 回复
    Note that the front glass panel is quite light. When reassembling I found it impossible to get the LCD free of dust with the computer lying on its back. I had success with standing the computer up, tilting the LCD down as far as it goes, holding the glass panel upright in front of the computer (about 1 foot away), lightly spraying both the LCD and the back side of the glass panel with compressed air, and then attaching the glass panel (with the computer upright). It took me 5 tries before it was completely clean of dust once the front glass was on.
    axel - 回复
    Although I do not advise it, you can substitute the suction cups with two strips of duct tape along the sides of the glass, with the tape attached to it's self in the middle of the strip
    Erin - 回复
    Tuandomino ini sudah di akui oleh para member member setia di dunia situs poker online Indonesia. Yang pertama situs ini sudah diakui dan mendapatkan sertifikat resmi oleh pusat server situs poker online.
    tuansakong99 - 回复
    Get out of here with your spam.
    Jason Zak -
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
43等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
一条评论
Good Instructions: Warning!, make sure all the screws are fully seated down prior to glass install. This is what happens when you don't:
http://www.youtube.com/watch?v=8kyRUZrdp...
Andrew Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 48
总计 29,284
