跳转到主内容
加入维修社区 - 创建账户
iMac Intel 20" EMC 2105 and 2118 RAM Replacement
你所需要的
  1. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: 步骤 1 中的图像 1,2 iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: 步骤 1 中的图像 2,2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 20" EMC 2105 and 2118 RAM Replacement: 步骤 3 中的图像 1,1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
结论
To reassemble your device, just follow these instructions in reverse order.
62等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 60
总计 37,004
