简介
How to replace the power button in an intel iMac.
  1. To get to the power button first remove the hard drive fan as seen in other guides.
    • To get to the power button first remove the hard drive fan as seen in other guides.
  2. This is a picture of the button in place with the connector to the logic board removed.
    • This is a picture of the button in place with the connector to the logic board removed.
    • There are three plastic pins protruding up from the main back case that the button fits over. They appear to be slightly melted and mashed to hold it in place. I used a pocket knife to pry it up and off the posts.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Here it is with the back plate of the button pried off.  This exposes a white plastic washer under it. Here it is with the back plate of the button pried off.  This exposes a white plastic washer under it.
    • Here it is with the back plate of the button pried off. This exposes a white plastic washer under it.
  5. The center of the washer has a center locking pin to correctly place it on the back of the button.   The washer is concave and the concave side faces the button,  This gives the button a spring to it so that it will pop back out.
    • The center of the washer has a center locking pin to correctly place it on the back of the button. The washer is concave and the concave side faces the button, This gives the button a spring to it so that it will pop back out.
  6. This is he back of the button that will now just push out.  Picture #2 is with the button removed. This is he back of the button that will now just push out.  Picture #2 is with the button removed.
    • This is he back of the button that will now just push out. Picture #2 is with the button removed.
  7. Test the button to see if it works.
    • Test the button to see if it works.
    • After replacing the button, use something (like a low temperature soldering iron) that will melt the tops of the white plastic pegs to secure the button in place.
结论
4等其他人完成本指南。
mayer
于2010年01月04日注册
581,254 信誉积分
创作了11篇指南
团队
MacHale Enterprises MacHale Enterprises 的会员
Business
1 名成员
创作了13篇指南
浏览统计数据:
过去的24小时: 3
过去的7天: 22
过去的30天: 116
总计 11,694
