跳转到主内容
iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Disconnect the hard drive thermal sensor from the top edge of the logic board.
    • Pull the connector parallel to the face of the logic board.
  2. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the two 9.2 mm T10 Torx screws securing the hard drive bracket to the rear case.
  3. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift the hard drive from its left edge enough to clear the inverter and pull it toward the left edge of your iMac to unseat the mounting pins from the chassis.
    • During installation, do not push the rubber grommets through the chassis with the hard drive mounting pins as retrieving them will require removing the logic board.
  4. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 步骤 4 中的图像 1,2 iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull both the SATA power and data cable connectors away from the hard drive.
    • Be careful when de-routing the hard drive thermal sensor cable from under the heat sink framework.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,304
