跳转到主内容
iMac Intel 17" Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac Intel 17" Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • De-route the bundle of power supply cables from behind the hard drive bracket.
  2. iMac Intel 17" Hard Drive Replacement: 步骤 2 中的图像 1,3 iMac Intel 17" Hard Drive Replacement: 步骤 2 中的图像 2,3 iMac Intel 17" Hard Drive Replacement: 步骤 2 中的图像 3,3
    • A hard drive thermal sensor may be present on some models. If your logic board is missing the hard drive thermal sensor socket highlighted in red in the first picture, skip this step.
    • Pull the hard drive thermal sensor connector away from its socket on the logic board.
    • Pull this connector parallel to the face of the logic board toward the top edge of the iMac.
    • Use a spudger to pry the thermal sensor and adhesive off the hard drive and install it in the same location on the replacement drive.
  3. iMac Intel 17" Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Press the hard drive bracket down to free it from the rear case, then rotate the top of the drive toward yourself.
    • Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force, so we recommend laying your iMac stand-side down on a table to avoid knocking it over.
    • If you have trouble releasing the hard drive bracket, it can be removed from the hard drive, by removing the two T8 or T10 Torx screws securing the bracket to the drive.
  4. iMac Intel 17" Hard Drive Replacement: 步骤 4 中的图像 1,2 iMac Intel 17" Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Lift the hard drive off its lower pins and pull it out of the rear case, minding the power supply cables that may get caught.
    • When reinstalling your hard drive, be careful not to push the two rubber grommets through their holes in the chassis. Retrieving them would require removing the logic board.
  5. iMac Intel 17" Hard Drive Replacement: 步骤 5 中的图像 1,2 iMac Intel 17" Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Insert a spudger between the SATA connectors and twist it to separate the connector from the hard drive.
    • Disconnect both SATA connectors.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,155
