简介
Is your iMac always mute? Replace the speakers.
工具
配件
无需配件。
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
Disconnect the IR board cable by pulling its connector toward the left edge of your iMac.
Remove the single T10 Torx screw securing the right speaker to the rear case.
Use the tip of a spudger to push the ears on either side of the speaker connector toward the top edge of the iMac.
另外一个人完成了本指南。
