本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace the camera board to restore iSight functionality.
你所需要的
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
在这个步骤中使用的工具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay the bezel front side down on a table.
If necessary, peel back the tape covering the camera board.
一条评论
is my first time i come to this instruction webs and got good explanation of my problem keep a good work MR.
