简介
Use this guide to replace your CR2032 PRAM battery.
  1. Lay the iMac display-side down on a flat surface.
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. Lift the rear panel slightly near the bottom of the iMac. Pull the rear panel toward yourself and remove it from the iMac.
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
    • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
    • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
    • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
    • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
    • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
  6. Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
    • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
  7. Slightly lift the AirPort bracket off the logic board. De-route the AirPort antenna through the slot in the AirPort bracket.
    • Slightly lift the AirPort bracket off the logic board.
    • De-route the AirPort antenna through the slot in the AirPort bracket.
  8. Use a spudger to slide the PRAM battery out from under its socket's metal clip.
    • Use a spudger to slide the PRAM battery out from under its socket's metal clip.
    • Do not bend the metal clip up, as it is brittle and will break.
结论
另外一个人完成了本指南。
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 19
总计 10,637
